I got 1 pair of each and tested them against each other in several FET based DD lights. I believe the 30Q beat the HG2 in 3 of 4 lights. This was a variety of lights, couple triple/quad (high amps of 9-11A), couple single (5-6A), etc. The 30Q did well, consistently better than any other high performance cell including all the 2500/2600's I have (HE2, HE4, 25Q, VTC5, AWT IMR 2500, EFEST, etc.). Not saying the HG2 did poorly though, but the 30Q's did it more consistently across all those lights. The tests were all from fully charged at start, down to only 30 secs of runtime, so not a great thorough test for sure. I'd love to see the dis-charge curves in a HKJ graph to compare these. Who knows though - there are variations from cell to cell, I even think from charge to charge, certainly age/charge cycles is a factor, so we may be splitting hairs.
The accidental XP-L dedomings are probably from the dome being right up to the edge of the mount - they even had to square off the dome because of limited space. If there is some slop space though between the LED alignment piece and the LED mount, it may cause some stress on the dome with torque applied. Wonder if making sure the LED alignment piece is sitting flat as possible, maybe even filing the backside down a little would help. Might lower the point of contact and not stress the dome as much. I have a couple XP-L's installed in a XML LED spacer and haven't had problems, but I don't fiddle much with them. If you do anything like tightening/loosening the bezel, be sure the LED has fully cooled down.
In this case I wasn’t soldering and hadn’t even used the light yet today. You can see in the pic that the dome is rotated, and stuck, in the centering ring. To me that says that it was twisted off by force. I can accept if this was user error. My best guess is the centering ring had popped up during assembly and wasn’t sitting down snugly on the LED base. That would allow it to rotate when the bezel was screwed on. Lesson learned. Be very careful during reassembly.
No, please do not misunderstand. I know you were not soldering and understand that you were screwing down the lens cap. I was saying that for whatever reason if XPL's have any heat whatsoever they can and will dedome. It isn't user error...it is something with the XPL in general.
Note that I tried the oil, solvents, electronics cleaner, and padded vise and vise-grips — and could not budge the stuck head on mine after doing all that.
So I set it aside.
Then, overnight —- I found it had come up loose (and the squashed O-ring had pulled itself back out from under the edge of the lens too).
I’d guess something took a while to dissolve or soften inside that was jamming the threads, or the jammed aluminum took overnight for the solvent/lubricant to penetrate into the jammed tight spots. Then the pressure was off the threads, releiving pressure on the bezel-glass-ring, and it all let go and moved.
Slowly, grudgingly at first, but it moved. Wiped out the threads carefully after that. (Could also just be there was crap in the threads when the light was first put together and it got stuck that way)
The 3D works fine except for the stutter when switching from Turbo to moon.
The 5A has many of the same problems already noted here.
defective driver with wrong levels: likely bad 7135
tight threads separating battery tube from head
I have a red Convoy S2+ and it blows away the BLF Manker A6. I had already outfitted it with Wight’s driver and TK firmware so there is no comparison. Actually, for some reason Wight’s original driver does not exhibit the turbo-to-moon stutter. The S2+ is heavier, much better build quality, and has a nice color and stainless steel switch.
EDIT: I managed to completely disassemble the 5A light using a vise using a leather belt as padding. The battery tube was easy to remove. I gave up on the pill/reflector but then they came apart easily after I removed it from the vise.
This light cannot just be redone by anybody else. It just is not that simple.
As for no engraving... it will be engraved for the purpose of marketing. It is not feasible to take a few and not engrave etc, etc because then it causes more issues. Bottom line...available in three tints..those are the only choices aside for the custom "bare" run of 100.
Just got mine in the mail! The knurling on these is awesome. Had a slight “nick” in one of the anodizing, but not a big deal.
I am having trouble with one of the tail caps though. Apparently one of my springs came out defective. The metal is blue and looks like it got super hot when it was being formed, and caused it to stick to itself instead of expanding out.
The light doesn’t seem to work, as the battery bottoms out on the retaining ring. I’m going to give Neal a shout and see what we can do. If I can find a suitable replacement in my random flashlight parts, I’ll probably just replace it myself.
I do have a question though. I’m trying to change from the group 1 modes to the group 2. I understand how to get into the “soft config mode,” and I see the light blinking. When do I turn the light off to select the mode? I’ve tried turning it off while the second set of flashes are going, also when it gets done doing the second set of blinks, yet I can’t get to the 2nd mode group for some reason (probably user error). Also, how do you toggle the mode memory. After doing 2 sets of blinks, it goes to a steady low mode. I turn the light off, or half press to go to a different mode, and the mode memory seems to stay on no matter what I do. Thanks for the quick replies guys. Finally got it figured out. Like I said, “user error”
Overall, huge congrats to bugsy for seeing this thing through! Absolutely beautiful product man!
The spring looks like a cell was in it and there was a short. It's happened to me a few too many times , looks way too familiar. Could be no damage to the driver or LED, but the spring would be best if replaced, or you could try pulling it up to regain the height, then add a bypass wire. Test out the LED and driver first though - insert a cell, ground out the cell neg. end to the bare end of the body/tube - could use a jumper wire, or even a screw driver.
I've used springs like this - if you can recover the spring height/tension. In the blue spots though it may have nurned off the conductive metal coating, so the spring may or may not conduct well - that's why I'm suggesting a bypass wire, then you don't have to worry bout the spring's conductivity.
Only if you are up to it of course . Could take the route of contacting BG.
