Thanks, that looks like i could work out better and if i need an even more softer spot and more flood i will absolutely test TK’s DC-Fix mod if i can find it or something similar here in Europe.
Is the X6 you gave to your dad a X6-SE with a FET driver? i thought it was.
I suspect the A6 will fit in the pocket nicer than the X6 also when i don’t need to use it, like on lit parts of the track.
I know how it is i just got my X6-SE 4C today finally, i am just itching to rip it apart to install the triple or the quad in it but i will try to wait for the X6 host+box instead, or at least take it night running before it mod it with something else than the 4C. I want to see how a warmer hue resolve important details at speed for better feet placement & traction in the dark.
Maybe i just FET mod it & bypass the springs to quiet the urge a bit :bigsmile:
I will have to get “The Boy” going on how to flash these drivers.
He should be able to figure it out with a little help and put that EE and ME Degree to good use
He should be able to do it with a little help like I said, plus I would like to learn a little more also.
A little hard to pin him down with all the bike riding/racing he is involved with.
FWIW, DC-Fix is from Germany; it’s probably easy to get some where you are. The “sand” variety works best for light diffusion purposes — not quite as nice as a frosted lens, but close. I have it on about half my flashlight lenses.
Also, here’s how DC-Fix compares to a zoomie (SK-68) at the same lumen level. It’s hard to see here, but the reflector-based light with diffusion film actually illuminates the ground a lot more evenly than a zoomie, because it gets brighter at the center (and thus provides a fairly even level of light going forward, while a zoomie rapidly gets dimmer with distance:
This shows a diffused light lifted off the ground by only a tissue box (~24cm); the beam would be even higher while running or biking, and thus smoother for more even illumination for a wide area:
I think both of the lights shown are a little more throwy than the EE A6, so I’d expect its beam to be even smoother.
Good info, i will be searching for some DC-Fix “sand” for my flashlight mod toolkit then.
And the “lights the ground more” sounds just what i need, if i can just find the perfect host i can start to search for the perfect tint for now i suspect warmer is better for gradient resolution for more optimal & safer foot placement.
But for snow the 3D tint is surprisingly good, it is almost easier to see at night with a flashlight than at mid day when everything is snowy & white & there is so much reflected light, but that can just be my general light sensitivity kicking me in the eyes & making me squint maybe i should try finding some good shades 8)
My favorite tint is the Nichia 219B ~4500K 92CRI emitter. My second favorite is Cree’s 3D bin. They’re very similar to each other, only the Nichia makes colors “pop” a bit more. The 219B is only capable of a third as many lumens as the XP-L though, so it’s not a good choice for this particular light.
TK, you should see the Luminus SBT70, 5000K with a 90CRI. The light coming off it’s factory no-dome is smooth and even, Linus Hoffman has a thread on a bigger big head Courui and he shows some pics of the bare emitter fired up, you should look. Not like a Cree at all, no color shift towards the edges, just smooth white nice light.
It’s a pretty big emitter, sitting on the MT-G2 star. It has a round die, not square, and a flat glass window covering it. Very low Vf, can be driven at low voltage or up to 10A+. I should point out that it’s a 3V emitter.
Interesting, so you also like the 3D, the only thing if i are going to get really picky is that colors look slightly washed out from it, i noticed that when i have been experimenting on mixing tints by shining several flashlights with different tints on to the same very strongly coloured batik fabric.
But when walk around inside with the 3D i often think to my self, i could actually want this for in house permanent installed lights, but i am planning to try the CRI 95 Cree CXA1304 LED for that instead & it should provide all the light quality i could ever want if i can make it work anyway
I have also noticed that i don’t really like tints from above the BBL line, and i wonder if a lighter retina make you experience the yellow in those tints above more strongly, because i have read that some people here actually prefer those 2C/3C tints, like for example Richard who likely have handled & experienced more tints than most have.
Or it could be that most haven’t experienced the 3D because it seems to be slightly rare at least in the top flux bin anyway.
I’ve used both 3C and 3D tints, and I prefer 3D. It’s closer to the slightly rosy hue of a 92CRI Nichia 219B, and it helps compensate for a bias in my eyes. I seem to be slightly blue-shifted, in that I can see some of the near-UV spectrum but have trouble seeing dim shades of deep red. So, the slightly increased red hue of 3D makes things look just about right.
As for yellows or warm whites, they make my eyes hurt. 2700K is painful and my eyes never adjust to it. If I try to read in that kind of light, the colors start rapidly inverting until everything is grey and all I can see is the contrast at the edges of shapes.
