Code now public! BLF A6 FET+7135 Light. Short 18350 tubes and Unanodized Lights Available
What kind of XP-L emitter will be installed? XP-L HI? Is the NW Led also an XP-L?
Thank you, Pilotdog68!
-Chuck
Not sure exactly what tints and bins it’ll be, but the emitters are intended to be regular XP-Ls (not the factory de-domed ones).
Nice on both counts, I guess I was misunderstanding mode 1 of the 4 mode option. I may just sacrifice the 7 mode option which I really like to keep it in 4 group just so I don’t have to go through moon every time if I like the spacing (and switch back and forth of course).
I don’t know how you’d do it, but if moon could be not in the normal mode chain selection and yet instantly accessible, that would be best for all I think. Maybe a press and hold for seconds turn on moon or something? Instantly accessible first, yet not necessary to go through in light level selection (heck turbo would be nice this way too and utilized a lot). I really don’t know if that could work or if its feasible to do, just an idea for fine tuning etc. :slight_smile:
Also, is it possible to reverse the soldering option and have mode memory as a default and soldering to turn it off? Mode memory on and 4 modes sounds like the preferred settings for a gift/quasi-“muggle”/non-soldering blf user, hidden but instantly accessible turbo and moon would be icing here too for a perfect UI.
Sounds like you want a light with an e-switch. There’s only so much you can do with a reverse clicky.
1 in nw if it’s still possible
Yeah, sounds more like it, but I thought TK is doing so well on this, so maybe she can think up a miracle, she is the light goddess after all :slight_smile:
Only 2 bytes left:-(
-Chuck
Mode memory can be toggled now in config mode; no need to solder anything.
With memory off, moon is immediately accessible from off and turbo is only one step away. Just click to turn it on, half-press while counting “one one thousand”, then let go. It should go directly to turbo.
Xmas is coming after all and I can never think what to get dad or stepdad… I’m already in at 477 I think, please put me down for 2 more, 1nw, 1cw, cheers.
On second piece in NW for me please. I am already on position 578.
That means over all I want to get two of these Flashlights. Thanks.
Seeing that this will be a gifting item for some and probably the most complex clicking flashlight I’ll have for a long time, will there be instructions for the mode clicking included with the purchase of these flashlights when finished?
Also, how do I go about practicing flashing this driver now? I’m worried I don’t have the needed items to connect to the board for flashing. Please point me in the right direction.
Not sure that they’ll include a printed guide, but you can at least use the online files included in the firmware repository. Those include a text manual and a state diagram (which is sort of in progress).
To flash drivers, I suggest reading the README file linked from the firmware thread. It includes a variety of resources which should be useful.
FWIW, here’s the current interface diagram… it’s a little busy, but I’m not sure how to represent everything visually:
Short press = ascending level (ie. low to high)
Long press = descending level (high to low).
In other words: Short press Increases brightness, while long press decreases brightness.
I LOVE this UI!
Thanks TK!
-Chuck
Great work TK, the discussions on the UI of the driver make the wait for this GB difficult. Can't wait to eventually hold the final product in hand to try it out.
I put together my 10th Eagle Eye X6 using a Fraen diamond pattern reflector and the Luminus SBT-70. I am very pleased with it, as, knowing it would be a power hungry hot rod, I modified the big Copper heat sink I designed for the Carclo quad so it would fit the reflector instead. Then, being so pleased, I engraved my name on it and the proprietary W/TK. Then I realized something. It had Richards MTN board and a simple 4 mode UI from way back when all the flashing first got started! SO, what choice did I have but to build a 17mm DD FET +1 driver from Wight and put ToyKeepers A6 firmware in it? :slight_smile:
The beam profile is very nice, semi large hot spot with very little spill. In the lower modes all you can see is the hot spot. And it’s a chunk, with that big head-filling copper sink. Typical for the Luminus emitters, it gobbles up the cell and is very stingy with lumens output. 17.52A for a measly 1500 lumens. You can feel the heat coming through the head in as little as 10 seconds!
I tested the LG HE2, HE4, Efest 35A and Samsung 20R. The LG HE2 yielded the most current draw, with the others falling surprisingly far behind. So, if this Luminus can draw over 17A from a single cell, then I highly recommend the use of the LG HE2 for any power hungry monster light in your stable. By comparison, the Panasonic PD yielded a miserly 12.23A. That’s the wonderful thing about these FET drivers. If you want to loan the light to a friend, simply put a less capable cell in it for safety. :wink: With a handful of variants on Li-ion cells, you can pick and choose for run-time vs. sheer output, almost like dialing in what you want it to do. :slight_smile: [35A did 15.47A, LG HE4 did 16.73A, Samsung 20R did 15.74A]
Have I mentioned that I LOVE TK’s firmware? :wink:
B42, don’t forget that with this driver you can simply back up if you go one too high. A long press, about 1/2 second, will reverse back to a lower mode if you find yourself on too bright a level. And the 2 groups are easily swapped by simply clicking a gazillion times (ok, 16 times) After 16 presses it quits responding… stop and watch for a blink to confirm you’ve changed to the other group. So you don’t have to give up anything. Use 7 modes for one thing, 4 for another. It’s always right there, a few seconds away. :wink:
Yeah it sounds nice, forward/reverse will help significantly I’m sure, haven’t used one like that yet. I just had a family visitor so I had some of the question/complaints about moon recently in my head.
I’ve read a few times now that the SBT70 is an underperforming heat monster, what made you want to try it? Have you done every other mod already? Wouldn’t surprise me!!!
Thank you Toykeeper, a TEST CLIP 8PIN SOIC was the missing piece of the puzzle for me. Had no idea something like that existed, was thinking it was going to be a pain and expense to clip something to each leg.
