Hi guys,
this forum was recommended to me by 8steve88 as a more tolerant option for discussing Chinese knives and other products that are looked down upon and restricted on some of the better known knife forums. Excessive amounts of snobbery and “attitude” ensured I just had to go an look for quality discussion elsewhere.
So, I thought I’d contribute by reviewing this little knife for you guys. Its not a chinese knife, heh, but it is Taiwan made. Presenting Cold Steel Hold Out 3:
(the photo isn’t mine, don’t have my camera at the moment)
Specifications:
Blade Length: 3”
Blade Thickness: 3 mm
Overall Length:6 7/8”
Steel:Japanese AUS 8A Stainless
Weight:2.5 oz
Handle:3 7/8” Long G-10
Pocket Clip: Stainless Pocket / Belt Clip
Got it from ebay for 30$ + 10$ for shipping.
Now I’m going to take it that you guys know your knives well enough so that I can skip to pointing out the qualities that _aren’t _apparent.
The good things:
+the knife is pleasantly balanced
+its also extremely thin overall, 9mm at its thickest
+the grind makes it both a good slicer and cutter
+the build quality is excellent
+extremely strong tri-ad lock
+the overall shape when open is very pleasing
+the tip is not as weak as it may appear (although I wouldn’t use it for prying)
The neutral:
+the thumb stud is not a single screw as it may appear, it is made of two pieces which actually screw into each other, but it is fully reversible
+grip of G10 is extreme, both a good and a bad thing
The minor flaws:
-mine came with minor rust spots on the tang, I’ve no idea why there exactly
-the factory angle is too obtuse for my liking and I honed the edge with my Spyderco Doublestuff + strop to take it to a good level of sharpness
-the slot for the flathead screwdriver on the thumb stud on my knife has a tiny nick on one side as if it wasn’t finished properly. it does not affect functionality
-the knife is less aesthetically pleasing when closed due to the impossibility of getting both the overall look and tri ad lock together (designers own words)
the clip is not usable in the factory knife its way too strong and the G10 is way too rough for it to actually clip onto anything. You will have to sand down the G10 beneath clip contact point to get it to work
the pressure required to disengage the lock is immense this knife is difficult to close
Overall use:
This is a light to medium use (take that as you will) EDC knife. Its small and light enough to carry around and will handle any and all cutting and slicing needs. Blade geometry makes it a mean cutter even when its somewhat dull. It requires decent pressure on the thumb stud to open and will snap back to the handle if it isn’t open at least half way so this is not in any shape or form a knife for self defense as it will be hard to operate under stress. It cannot be handled “carelessly” without some risk.
However, once open it is as closed to a fixed blade as a folding knife can get, so it can, in fact, take quite a beating.
Why buy it?
Well, the build quality is better than on other china made 30$ knives by Kershaw, CRKT etc. Cold Steel really enforces the QC and builds robust knives. You get more for your money here, comparatively speaking. It also functions well as the tool it was intended to be, unlike many knives with swedges and grinds starting half way down a small blade that offer more in looks than in cutting ability (if your 30-40$ knife is outcut by a 9$ opinel then you have a problem). I recommend it.
