Hmmmmm…… that does “ring a bell” somewhere back in my memory banks.
Seems like they had left their light on ‘high’ with the cover on and it got a hole melted in it…… ??? ……
And they found the substitute then….
That is all I remember. … IF IRRC…… :person_facepalming:
I’ll search around & try to find more.
I ordered Z1 lens caps from Jaxmans Aliexpress store for my Cometa”s, they fit perfectly.
I also ordered Z1 lenses to replace the extremely poor Cometa stock lenses, that were very brittle, scratched & had dirt & imperfections in the glass itself.
With the Z1 lens, led wires changed from 24awg to 20 awg & spring bypasses I managed to get over 1200 lumens as opposed to the 960-980 lumens mine produced stock & a much nicer tint due to the lens.
Yep, either way one goes they are cheap “b-h”; your right.
Since this has been mention again and brought back to my attention I am gonna look at the local Lowes Building DSupply and see if they might have some of those opaque ones. Quite a few times when messing with my Cometa’s or Z1’s I have almost done what the guy did in the “meltdown post”. :person_facepalming: I just happened to recheck before the cap melted.
If it was on it would be more evident with the opaque cap.
And just to be clear, when I said “you had done good” above. I was talking about the way you “rebuilt” your ’under-built’ Cometa.
It/they turned out very nice and much closer to what they should have been from the very beginning! :+1:
I also replaced the lens to a Z1 original,and I had more throw plus better tint.I haven’t changed cables neither did spring bypass, because I can’t do it myself .
They don”t seem to list the lens caps separately on Jaxman”s Aliexpress site any more but I am sure if you message Jaxman either on here (they are a member) or at their website they will sell you lens caps.
Failing that those 52mm pipe caps in Teachers link will work fine & are cheaper than Jaxman lens caps Page Not Found - Aliexpress.com
Sorry for resurrect, I ordered one of the Cometas in first batches and barely tested it. Is it not safe to use without modifications? What must be done to ensure safe use?
