Continue the upgrade plan. We have a new idea with plan to make a separate power bank for it. It will also be a holster, everyone can carry it easily everyday. Just like the Glasses Case
How about your Think. Or comment your better idea and opinion.
Rmove the extra clip, we needn’t
Exchange to single-way clip
Stay 2-way clip
0voters
May 5 2025 updated
Wurkkos HD01 Pro equipped with
①Front spot light green laser UV light
②Side flood light RGB light. ③2 buttons switch
It LIVE on Amazon now**-** USAorGermany (Just check its features easily)
Comment anything you wanna do with flashlight there. We plan to upgrade it to make it more practical, useful and high effective. (Thanks for Mond photograph)
↓↓We’re obsessed with “overengineering” budget lights!! ↓↓
Sunlight in Your Pocket: 4000 lumens + 600m throw. Yes, it can literally light up a football field.(Just a joke lol)
Marathon Runtime: 8+ hours turbo mode. Includes 5000mAh battery more portable than 21700– “low battery anxiety” shouldn’t exist (My dreaming battery).
Tactical Swagger: Strike bezel for… uh, “convincing” stubborn objects. Sticks your car hood/workshop fridge like a boss.
Real Talk:
We hope to spend enough time (maybe 18 months) to develop because we kept blowing up prototypes (RIP version like TS10 ; )
I have a non-pro HD01. Very impressive. Better for many uses than the much more expensive Olight Arkfeld Ultra. The HD01 has a much tighter beam, can use the main emitter in any brightness with the laser, has a side light, and weighs less.
From my experiences with the HD01, I suggest the following improvements for future models:
For many users, a shortcut to turbo is one of the most used features. The HD01 has a double-click shortcut to turbo. However, from what I’ve read the HD01 Pro has no turbo shortcut.
Instead double-click activates UV. I suggest making double-click activate turbo and 3 clicks activate UV. If you want to keep the 3-click shortcut to strobe, then make 5 clicks activate UV. Or maybe 1 click+hold.
The corners at the back top end of the light feel sharp on the hand. It would feel much more comfortable if they were rounded off.
Offer an optional low-profile clip that is 1-way bezel-down only.
Unfortunately I am more interested in quality than low cost.
Removable battery. This is the main reason I won’t buy one. I don’t care that it is longer or heavier or fatter or…
Main LED in 3500-4500K. The current 90CRI is nice, but I want more details available about the LED being used and won’t accept 6000K as the only option.
520nm Laser. Or even more unique wavelengths. Not the cheap 532nm DPSS diodes that leak 1065 IR and are ancient laser technology nowadays.
UV is fine (365nm required), deep red 660+ nm is also useful.
Better UI than just a couple of buttons. Magnetic switches, anduril for the main LED, independent control of R,G,B,CW,WW LEDs in the side array or the ability to do custom programming either via Bluetooth or a USB cable via an open source interface.
I’ll add my two bits to support the need for a neutral/warm led option. Personally I don’t really care about a laser. I’m very interested in this form factor, but I won’t even consider a light with 6000k as the only option. I love a Dedomed 519a 4000k/4500k, fwiw…
