Comparing 20 LEDs (with and without high CRI) in 14 Convoy s2+: final personal observations
Done about 3-4 hours of testing...
So, now I got those out of the way, I can concentrate on the LEDs.
I will remove all the AR coated lenses, and replace them with clear lenses..
I will keep #2 for my SST20 4000K testing :)
Cecking 14 SST20's side by side:
observation: you can see a difference in the color of spill, while the actual measurements of the beam from a distance are close (CCT and CRI).
Next observation:
It's hard to show the difference in spill on camera.
I was thinking about my last post and it got me wondering (Apologies I haven’t been following the opple thread so I don’t know it’s capabilities and sorry if this has been discussed already).
I got the impression it measured Ra as in rendering average which is technically accepted as for R1 to R8. However the opple as far as my quick search reveals does not measure individual colours so I was wondering does it measure cri average across all 15 colours…??? If not how did it separate R1-R8 from R9-R15 ?
Good question!
I thought it's just a combination of all measurements, but how would we know if it measured R9? Maybe it does, but it's just not in the software?
Maybe somebody more knowledgeable than me could answer that question :D
Yes, this is where you get into areas of tint distribution and uniformity. It has a lot to do with the reflector and some to do with the LED construction. Some have a very even tint distribution with very little variation in tint between the spot and spill, some don’t (like gen 2 xhp, xp-l and gen 3 xp-g). Some sst40 have it along with some sst20s. OP reflectors help with this.
Here comes the next data dump…
Just for reference
. . . . . Mode: LOW(est) Mode: High (center) Mode: High (spill)
# LED Notes CCT CRI CCT CRI X= Y= DUV CCT CRI X= Y= DUV CCT CRI X= Y= DUV
1 Nichia 219B Fasttech 4000K 90 3703 93.7 0.3991 0.3985 0.0048 3948 91.2 0.3871 0.3933 0.0057 4111 93.1 0.3758 0.3733 -0.0002
2 SST20 Fasttech 4000K 95 3965 95.3 0.3836 0.3825 0.0018 3889 94.6 0.3852 0.3776 -0.0014 4083 95.1 0.3743 0.3628 -0.0048
3 Nichia 219CT Kaidomain 4000K 80 3779 80.5 0.3936 0.3912 0.0030 3793 80.6 0.3908 0.3837 0.0003 4267 81.8 0.3683 0.3631 -0.0028
4 Nichia 219B R9080 v1 From Djozz 4500K 4499 94.6 0.3607 0.3619 -0.0008 4511 97.1 0.3577 0.3455 -0.0080 4382 97.5 0.3610 0.3434 -0.0103
5 Samsung LH351D Kaidomain 4000K 90 4095 93.3 0.3794 0.3859 0.0045 4080 92.4 0.3787 0.3805 0.0023 4088 92.1 0.3767 0.3733 -0.0005
6 CREE XPE Q5 5D2 Kaidomain 4000K - 4593 80.6 0.3564 0.3523 -0.0040 4588 80.4 0.3556 0.3456 -0.0072 4063 79.4 0.3755 0.3650 -0.0041
7 CREE XPG3 S5 5C1 Kaidomain 4000-4500K - 4017 71.4 0.3798 0.3756 -0.0004 4158 71.1 0.3727 0.3666 -0.0025 3962 69.5 0.3823 0.3772 -0.0003
8 CREE XTE S4 5A3 Kaidomain 4000K - 3883 70.3 0.3890 0.3904 0.0039 3952 68.9 0.3843 0.3832 0.0019 3887 69.5 0.3861 0.3807 0.0002
9 CREE XPL2 HD v3 5A Kaidomain 4000K - 3879 79.7 0.3902 0.3943 0.0053 3921 78.4 0.3880 0.3925 0.0051 4064 79.1 0.3792 0.3804 0.0021
10 CREE XPL HD v3 5A3 Kaidomain 4000-4200K - 3746 72.8 0.3981 0.4014 0.0063 3927 70.6 0.3871 0.3901 0.0042 3994 72.3 0.3821 0.3813 0.0016
11 CREE XPL Hi U6 5A3 Kaidomain 4000-4200K - 3969 78.0 0.3856 0.3909 0.0050 4078 76.8 0.3798 0.3847 0.0039 4131 77.2 0.3773 0.3827 0.0037
12 Nichia 219B v1 R9080 from Djozz 4000K - 4059 94.7 0.3795 0.3806 0.0021 3881 96.5 0.3829 0.3682 -0.0048 3686 96.8 0.3900 0.3675 -0.0007
13 Nichia 219B intl-outdoor 4500K - 4739 94.5 0.3522 0.3511 -0.0031 4736 95.8 0.3505 0.3371 -0.0097 4731 96.2 0.3502 0.3336 -0.0115
14 Nichia 219BT Kaidomain 4500K 92 4555 92.9 0.3612 0.3764 0.0060 4571 93.9 0.3580 0.3585 -0.0015 4384 94.2 0.3645 0.3629 -0.0016
15 LH351D 5000K Kaidomain 5000K 90 4675 94.2 0.3563 0.3690 0.0043 4902 93.3 0.3492 0.3668 0.0059
16 LH351D 5700K Kaidomain 5700K 90 5359 97.4 0.3356 0.3388 -0.0026 5649 96.2 0.3292 0.3345 -0.0019
17 SST20 2700K from Djozz 2700K 95 2688 97.1 0.4642 0.4171 0.0020 2663 95.7 0.4646 0.4148 0.0012
Edit: 2022-08-18: I removed 6,7,8 as being the ugliest, and replaced them with LH351D 5000K CRI90, LH351D 5700K CRI90, and Luminus SST20 2700K CRI95
The beam of some of the lights are very ugly. It's probably a combination of smooth reflector + not correct reflector spacer.
High spill is about half way between the edge of the hotspot and the most outer visible ring.
New entry to my CRI journal.. lol
You don't really need to comment on this, but maybe you can relate to this.
I went out last night with all 14 lights, and tried them 1 by 1.. and not side by side... on purpose...
So far, I prefer the cooler ones, likely 4500K+
4000K is just a bit too yellow for me, and I prefer to have white really be white..
A couple of other observations.
If a beam was kind of ugly, I had a hard time liking it... even if it was high CRI or not.
Secondly, using the lights 1 by 1 it was difficult to really say I prefer High CRI, because of the different beam profiles, tints etc. At the moment I would say: I rather have a low CRI LED with a great beam (without artifacts, and smooth transition between hotspot and spill) than a high CRI that doesn't fit the reflector/spacer.
Next up: put some DC Fix on some of the lights with the ugliest beams...
Tested all of them with some DC Fix, and man, that helps a lot.. Even the ugliest (which are still a bit ugly) are much better.
Just testing this in my room.. and don't notice much of high CRI... maybe if I'd really concentrate, or use 2 lights simultaneously.
I think a lot really has to do with what you’re doing with the light, indoors or out. Let’s say you’re indoors. If you’re just scanning a room or using the light to walk from one room to another the CCT and CRI may not matter a whole lot. B
If you’re in an unfamiliar building and going down dark carpeted stairs or there is various clutter or debris on the floor and you’re trying to understand what it is you’re stepping on or you are trying to identify a whole lot of objects in an unknown environment, then the CCT and the CRI matters a whole lot. If you’re outdoors walking on an unfamiliar trail where you need to be able to watch your footing for rocks, roots with various colored dark leaves on the ground, again warm and high CRI matters. Looking at various things in your house that you are familiar with is not always a good test. Standing still while outdoors is not always a good way to test things. When moving, indoors or out, it’s more important to be able to clearly identify what various things and objects are. The type of environment you’re in and the distance you’re trying to see things at is also extremely important. I do think that cool white might actually be better if you’re in a snow covered environment. The snow reflects and “amplifies” if you will the light so you can see more of everything with cool white. I’m getting a little bit off the track but the point is in actually using lights you are usually moving to some extent. Try to add that into comparisons to some degree.
I think so too. It depends on the use case. So everybody should probably test it for themselves, and see what they prefer in their use case.
Most of my light usage (99%) is not in the woods, or dark unfamiliar buildings with clutter and debris. But I think, in those cases, a good beam profile is likely even more important than high CRI (with crappy beam profile). Do you agree? That's what I noticed, for EDC and close range, I really like a smooth beam (for example with DC Fix). It probably has to do with the 'stress' on my eyes. A smooth beam feels more comfortable.
Since I am checking what I personally prefer, my preference goes to 4500K+ as of now. I don't really like warm white.. Still have to test some 5000K+ and see if I like those better.
I still have to replace some of the LEDs
Will likely buy a couple more, like the 519A 4500K, 5000K and 5700K, just for testing
Adhesive Film test
This is not actual DC Fix, but something I found in a local store... (Action in the Netherlands)
Measured at approximately 70cm
Center of the beam.... in one of the highest settings I could find...
Ambient temp 27 degrees Celsius
. . . specs specs Mode: High (no film) Mode: High (with film)
1 Nichia 219B Fasttech 4000K 90 3948 91.2 0.3871 0.3933 0.0057 3909 92.9 0.3862 0.3843 0.0019
2 SST20 Fasttech 4000K 95 3889 94.6 0.3852 0.3776 -0.0014 3926 96.1 0.3820 0.3713
-0.0030
3 Nichia 219CT Kaidomain 4000K 80 3793 80.6 0.3908 0.3837 0.0003 3823 80.5 0.3899 0.3851
0.0012
4 Nichia 219B R9080 v1 From Djozz 4500K 4511 97.1 0.3577 0.3455 -0.0080 4280 97.4 0.3653 0.3505 -0.0081
5 Samsung LH351D Kaidomain 4000K 90 4080 92.4 0.3787 0.3805 0.0023 3919 92.5 0.3861 0.3853 0.0023
6 CREE XPE Q5 5D2 Kaidomain 4000K - 4588 80.4 0.3556 0.3456 -0.0072 - -
7 CREE XPG3 S5 5C1 Kaidomain 4000-4500K - 4158 71.1 0.3727 0.3666 -0.0025 - -
8 CREE XTE S4 5A3 Kaidomain 4000K - 3952 68.9 0.3843 0.3832 0.0019 -
9 CREE XPL2 HD v3 5A Kaidomain 4000K - 3921 78.4 0.3880 0.3925 0.0051 3859 78.6 0.3908
0.3934
0.0047
10 CREE XPL HD v3 5A3 Kaidomain 4000-4200K - 3927 70.6 0.3871 0.3901 0.0042 3824 69.7 0.3938 0.3984 0.0061
11 CREE XPL Hi U6 5A3 Kaidomain 4000-4200K - 4078 76.8 0.3798 0.3847 0.0039 4013 77.7 0.3830 0.3876 0.0043
12 Nichia 219B v1 R9080 from Djozz 4000K - 3881 96.5 0.3829 0.3682 -0.0048 3694 96.4 0.3914 0.3730
-0.0048
13 Nichia 219B intl-outdoor 4500K - 4736 95.8 0.3505 0.3371 -0.0097 4464 95.7 0.3590 0.3452 -0.0086
14 Nichia 219BT Kaidomain 4500K 92 4571 93.9 0.3580 0.3585 -0.0015 missing
15 LH351D 5000K Kaidomain 5000K 90 4902 93.3 0.3492 0.3668 0.0059 4766 92.9 0.3536 0.3695 0.0055
16 LH351D 5700K Kaidomain 5700K 90 5649 96.2 0.3292 0.3345 -0.0019 5531 96.1 0.3317 0.3378 -0.0013
17 SST20 2700K from Djozz 2700K 95 2663 95.7 0.4646 0.4148 0.0012 2604 96.2 0.4662 0.4103 -0.0006
First few columns without the film are from couple of months ago..
Today is at a different distance.
My observations:
CCT : the adhesive film LOWERED the CCT in most tests.. 11 vs 2 (at the moment of testing, I can't find 1 of the lights)
CRI: the adhesive film has mixed results... 7 had a higher CRI, and 6 lower... So this is not a clear difference... the differences were also pretty close to the initial measurements.
DUV: the adhesive film mixed results.... 7 had a Lower DUV, and 6 higher or the same... no clear 'winner'.
So it does seem to affect CCT more than anything else.
This may be different with actual DC-Fix..
I just ordered 3* Nichia 519A... 4500K, 5000K, and 5700K....
Received my order.... that took only 9 days.. very quick.
Okay, I went for a 1.5 hours walk with 14 flashlights..
I already replaced nr 6,7,8 because they were the worst. And replaced them.
6 became 15: LH351D 5000K CRI90
7 became 16: LH351D 5700K CRI90
8 became 17: SST20 2700K
Next week I will check the 519A.
So far, some more of my observations..
Just a brain dump.. I just came home, and it's about midnight now.
  1. The more I tested, the more difficult it was to get my mind clear on what I liked :) Especially if I kept switching between 2 different lights.
  2. I have 2 Nichia 219B 4500K, and they differ in tint.. So, you don't always know which one you will get. Even if you think you like 1 LED with a specific type 219B and specific CCT 4500K, you might actually get one with a different tint.
  3. The 2 Nichia 4500K were one of my favorites. And depending on the environment, I preferred the 1 over the other. #14 was nicer if there were just green environment (grass), while #15 was nicer when walking on gravel, with grass on the sides.
  4. The width of the beam is actually (in certain cases, like cycling or just walking) more important than just having high CRI.
  5. I would have liked less of a hotspot with the Nichias...
  6. DC Fix (and alternatives) make a nice improvement, to get a smoother beam with wider 'hotspot'.
  7. Still, if there was the option that I could choose high CRI, I'd get it... because... why not just get the extra 'color information'. But wouldn't say no, if it has a nice tint, even without high CRI, especially for my personal use.
  8. In some circumstances, the lower CRI were less interesting (I only had #9, #10, and #11 left) and when walking in the grass, they made it look a little unnatural green.
  9. High CRI helps with showing some brown stuff in grass better.. poo
  10. I still don't know which of these 14 is my favorite
  11. High CRI doesn't matter in low CCT.. because it's much too yellow anyway.. color or no color :D
  12. I don't really like 2700K in nature
  13. Cool white makes me feel a bit more at ease.. the warmer the color the 'scarier' it feels to walk in nature
  14. My preference is still somewhere between 4000 and 5000K
  15. I don't have a very good 5000K yet, so I hope the Nichia 519A will be better than the LH351D
  16. The LH351D 5000K was just a bit on the greenish side, same goes for the 5700K. I didn't mind them too much, since I kind of like the cooler white, except for the times when I started to switch between these and the Nichias.
  17. Now I have to replace 3 LEDs with the Nichia 519A's I just received... I will probably replace the low CRI CREE ones.
Good info ChibiM. :+1:
Looking forward to your impressions of the 519As.
I'm curious as well :D
Hopefully I can share my observations soon
Ughh... just got around replacing the LEDs..(which was overdue)... and noticed that I likely got the wrong one(s).
The 4500K I ordered turned out to be measuring 4000K
The 5000K is spot on, around 5000K
The 5700K measures around 5100-5200K
Hmmm... so, the testing will take even longer :(
Do you prefer the 5000K 519A or rather the 5700 one ChibiM?
I don't know yet.. I only replaced them today.. and I'm not sure whether I got the correct ones.. my 5700K reads between 5100 and 5200.. so I assume that's not correct..
Hopefully I'll know more soon...
I will probably do another round of tests with just DC fix installed.. Last time I just added in front of the beam, but still tested most of them without for most of the time.
I think you did get the right ones. 4500K 519As are infamous for measuring way below the claimed CCT, I've seen at least one review that puts it under 4100 behind TIR optics. 5700K is known to measure lower than advertised as well, if you're getting 5200K you must have the right CCT because every other CCT will measure 5000 or below.
What is surprising is that the 5000K is spot-on; they usually measure 4700-4800.
The 5000K is actually spot on, for real. The other 2 aren't.
I'll wait for Simon's reply.
