I was out in the forest last night with the intention of trying out my favourite torches, and comparing them. It was pretty much pitch black, and not too crowded with trees to give us an idea of what the distances and beam patterns were like from the various torches. Please note, the following is in NO WAY scientific, I have no figures, it was just a comparison for my eyes.
This is what I had with me;
Fenix RC40 (6000 lumens)
Fenix TK41 (860 lumens)
Fenix PD35 (850 lumens)
Malkoff M61 MD2 Nichia 219 with hi-lo
Zebralight SC600 (Mk II)
HDS EDC Rotary (250 lumens)
Streamlight Microstream (only because this is always with me, not necessarily for direct comparison)
My most recent purchase was the biggest daddy of them, the RC40. With it’s lowest setting of 50 lumens, it’s surprisingly very useful. Creates a very nice floody beam, handy around the forest if you don’t mind the weight and size of the thing. We were able to get it to the edge of the forest where we had access to a field, and at the second high level (4000 lumens) it shines the whole thing up. Massive hotspot, and a most useful widespread light that enables you to see your peripheral fairly easily. This thing is designed for proper search and rescue, most impressed with it’s distance capability and for lighting up everything around whatever you have in the hotspot. The settings (in lumens) are - 50, 500, 2000, 4000 and 6000. I don’t like this spacing, you can’t tell much difference between the 2 top settings, I think a more suitable layout would have been - 50, 500, 1700, 3000-3500 and then 6000.
The TK41, believe it or not also does great with distances. And until I saw the RC40 in action last night, I thought it was a good wide pattern beam, but in comparison it is fairly focused. Not to say it’s not useful, but not as much as the RC40. It has a quite focused hotspot, which does really well out in the distances and you wouldn’t really complain if you had to use this one in a farm/field sort of setting. Though you do have to move it around a bit to get the full picture lit up. Whereas with the RC40, you sort of shine it in one direction and a whole lot left and right of it lights up also. In the forest setting, I found it’s not as useful due to the focused pattern, but then it’s designed for that anyway. The spacing for the settings are spot on, each level gives out a perception of getting noticeably brighter. One of main major advantages of this torch is that it uses AA batteries, for those that may need to get some in an emergency from your local shop, very handy indeed. In the 2 lowest settings, it is more than adequate for your daily around the house/forest sort of jobs. And a helluva lot lighter/smaller than the RC40.
Both of the above, really only suited for long distance, but you probably already knew that anyway. I know for a fact that these will be assigned to the back of the car and will be left there, only taken out if specifically needed. Let’s face it, the RC40 will be taken out for fun ![]()
Now the next 2 that are similar in design, battery useage and output: Fenix PD35 and Zebralight SC600 II. Although the SC600 is smaller in physical dimension, it’s more impressive in it’s output (relative to it’s size).
The PD35 (only when compared to the SC600) has a more defined hotspot, and so throws further. Now let me clarify, the hotspot is fairly large and the spill is also large, so as a work light and around a camp setting it’s mega useful. It fits in the hand beautifully well, I love the tactically positioned forward clicky to switch it on/off and then the side switch to switch between the modes. Lovely design in that regard, IMO. Really, I have nothing bad to say about it. It’s lowest is around 10 lumens IIRC, which is fine in the dark. A lower setting (sort of around 1-2lumen) would be better but really can’t complain. And the highest of 850 is kinda overkill in the forest setting, obviously, but it’s useful for throw when needed. Nice beam, nice throw, nice settings, nice runtimes, nice torch!
The SC600, was disappointing for me. I always regarded this highly, and it does a really good job of lighting up every friggin thing in the way. It has the most useful modes, 6 that are readily available. A really low low for those night adjusted eyes, and a hugely massive high for creating a lightbulb-like effect right in front of you - that actually goes a decent enough distance (at least in the woods environment).Where it was disappointing was I found the PD35 more useful. Because of the hotspot in the PD35, you can have it pointing downwards and it lights your way and whilst keeping it at the same setting you can move it upwards straight ahead and it will show you in the distance. With the SC600 I found to have it light the way at your feet you generally have it a lower setting, but to see ahead in the distance, you had to bump it up a notch. Now I’m nitpicking here obviously, but I didn’t expect that.
One flaw I found with the SC600 last night, when I clicked once to get to high, it would go down to medium. I tried it a good few times and it did the same each time. I checked the battery levels and it flashed twice showing at least 50% battery level available, so it shouldn’t have done that. I switched the battery from my Malkoff to the SC600, it showed 3 flashes of battery available and then it was able to use the highest mode. Not happy with that. Overall, I was going for the SC600 less than I thought I would. I really wanted this one to come out near the top.
The HDS EDC Rotary, with around 250lumens highest and I have no idea what at the lowest, shows it’s not all about the lumens. A whole bunch of factors come into play. The reflector depth, width and it’s OP quality/design. This was the most fun light to play with, with a single hand you can ramp it up to the highest and then down to the lowest using the dial, SUPER handy and useful. The lowest seems ridiculously low when you see it at home during daylight. But out when it’s really dark, that lowest low is actually useful for close up work (when we were making a fire and didn’t wanna lose our night vision). In your head, you have this concept of “what the hell is 250 lumens going to do”, a whole lot really if it’s used to it’s fullest potential. If it was up to me, I think I would have wanted only another 50-100 lumens at max output, and that’s being greedy. From the lowest, to the highest, each increment is noticeable to the ere and each time it goes up, it’s a useful increase. Not too low an increase, not too high an increase, just perfect. I think it has 24 stages? The light this puts out is bloody useful!! Great throw, great spread, evenly done from the center to the edge, lights up everything and you could want no more!! This light showed me last night it’s not all about the lumens, and also what an expensive light can do. I LOVE this one!!! Definitely one of my favourites!
Now the Malkoff MD2, the winner of the night! This was my only warm/neutral tint light, and each one of us loved it for that reason. I’m not saying that’s why it wins, but this was the first thing we all noticed. How the tint makes a massive difference. It allows everything to be seen the way it should appear to your eyes. Perfection as far as tint is concerned. The output, a low (I think it’s 10-20, I forget), and the high I think is around 250-300. With night adjusted eyes, the low is perfect, for around the camp, and when walking also. Twist the head, get it to max and wowza! Lumens wise it may not have the highest figure, but with the eyes, it really is plenty bright enough. MASSIVE spread of beam, flawlessly done from edge to edge, no discernible artefacts, no visible hotspots, no noticeable dark rings/spots in the beam and this thing lights up all that is around you!! What a beautiful beam indeed! And the quality of the construction is easily top notch!! The head is silky smooth to twist from high to low and that clickly, with a joy to click! This is my absolutely most favouritest torch of them all!!!
And the biggest surprise of the night, the Microstream. I thought it would be put to such shame, so badly in the company of the bigger torches, that it would be laughable. Not so, has a great throw with a very useable wide beam on it. Muchos impressed, don’t underestimate this one guys. Should definitely be in your collection if you like single AAA lights!!
Thank you for reading, and sorry for rambling. Like I said before, it’s not meant for any scientific purposes, only for me to convey how these lights were when compared to each other. If you have any questions, please feel free to ask.
Some random images from last night
