I had posted on reddit, but I didn’t want it to be taken the wrong way so I deleted it. A forum is more suited for discussion anyway.
I’ve been selling Convoy for 7+ years and since Covid the quality control has been getting worse and worse. This thread is about bringing these things to Simon’s attention and to hopefully provide a solution together as a community.
This is a list of issues that I find regularly:
- Flux splashes on LEDs
- Screws missing from mcpcb
- Screws left loose to try center the LEDs with round gaskets
- LEDs off center with round gaskets
- Dusty reflectors / lens
- S2 UV ships without a gasket causing bad focus, short circuit risk (S2+ UV is fine)
- Remote switches with poor soldering and cold joints (not always, but encounter often)
- Getian GT Red & Green badly over driven (more on this below)
- L21B new batch with Osram LEDs out of focus
- Batch inconsistencies concerning the focus
- 3X21C/D with sharp cell slots shredding wraps (I sand every unit)
- Buck/boost driver issues (fixed, but old batch still shipping)
The Getian GT Red and Green are paired with 8A drivers. I measured the lumens for both at 4A & 8A to find at 8A the output is less than at 4A. Simon said they won’t burn out until 9.5A, but I want max output at that sweet spot, not LEDs being over driven and shortening their life. The datasheet doesn’t show any max current, but it’s certainly not happy with 8A.
The new L21B batch is out of focus with reflectors that have a 9mm hole. I found that an extra 0.5mm needs to be added to the existing gasket. Simon now uses a thicker round gasket for the SFT40, which has helped, but still around 50m less than previous batch, needs 0.2mm added if you care.The Osram LEDs are what currently perform the worst. The CLSNM1/PM1 now comes with the larger 4040 gasket because they’re 0.2mm thicker than the 3030, this makes them now harder to center. The range is roughly 150m less than if an extra 0.5mm is added to the 4040 gasket. Results in a larger corona with a smaller hotspot.
The current C8+ batch of reflectors required thicker black gaskets. This shows with the new L21B batch that there’s inconsistency from batch to batch.
The round gaskets with off center LEDs are a problem, why isn’t this an issue for other brands?. Sofirn and Wurkkos don’t struggle with this.
I think the cause for poor QC is that so many people are requesting too much from Simon. He’s getting so many requests for a bazillion different LEDs, drivers, models, that it’s too hard to try monitor what goes on with all the different options available. This is a reason for concern when QC is getting worse. We should put the brakes on a bit and try requesting more attention to the QC and fix that first before anything else. Maybe, just maybe, Simon needs to reduce how many options are available for each flashlight model. This would be to ensure those LEDs used are focused correctly from batch to batch. Then leave it to the individual to mod each model with all the LEDs and drivers that are available.
