Need help with condensation issue. My Ultrafire 502B and Uniquefire UF-T20 both form condensation under the lens after a short period of use.
Why does this happen and is there a remedy? These are both new lights.
Thanks
I find it still happens on lights over 3 watts with a 30mm+ lense even if you do it in humidity of around 40%. It only shows in cold weather though, more so if there’s airflow onto the lense e.g. when running. It’s pretty hard to stop.
The only relative success I’ve had is with removable bezels. I loosen it, turn it on until it’s hot to touch, lift the lense a mm or two, count to 20 and close it up again. That normally helps.
I know this is totally over the top, but I assemble most of my lights at work under the nitrogen hood on the selective-solder machine Nitrogen carries no humidity, so there is no such thing as condensation
Hm, interesting, didn’t knew that. I would recommend take whole flashlight apart and use hair dryer. That will dry all parts in just few minutes.
Rise and that silicon stuff could work as well. BTW, when that silicon “do not eat” stuff is “full” and will not suck more moisure? How can you distinguish a new from used?
Most of my lights fog up when I get them during the winter. After being hauled around in freezing trailers, cold postal trucks and an equally cold mailbox, entering a warm atmosphere just steams them Up. Usually their okay after being acclimatized, but if it seems like there is a lot of moisture I’ll take them apart and place the head bezel down on a warm radiator for a couple of days.
Attn. Scaru. The radiator trick is also great for torches that have gone through a wash cycle.
