Confirm my L2 and c8+ 3v xhp50.2 builds
Hello hello, I’m looking for feedback on my first high power mods (i finally built my first xpl hi yesterday) I want to make sure I get my first builds right for my xhp50.2 setups, am I doing this right?
L2:
  • 3v xhp50.2
  • Noctigon XM20 20mm Copper MCPCB
  • FET + 7135 Driver - 20mm - MTN-20DDm (bistro firmware)
  • 18 gauge wires from driver to mcpcb
  • 18 gauge spring bypass at tailcap switch
  • stock switch
c8+:
  • 3v xhp50.2
  • FET + 7135 Driver - 17mm - MTN-17DDm (bistro firmware)
  • Vinh’s v54 tailcap switch
Everything is good, but just confirm that you will only be using the 1x26650 tube with the Convoy L2, as not to burn the LED from too high voltage.
confirmed, thanks for confirming that :slight_smile:
Are the drivers simply drop in? In another worse, no need to flash or any software related stuff I should start reading up on for this build?
You only need to drop them in, and solder them.
