I want to run my C8 at 100% always and only have on/off
Can I bypass the driver and run it direct on a XPL LED?
Any other suggestions for a cheap mod without destroying the existing driver?
One of the mode options in the Clear Convoy C8 is 100% only.
Always 100%!? Don’t forget to buy gloves too.
If you bypass the driver, you’ll ahave a direct driven emitter which is quite extreme.
Depending on the battery you use, you’ll see some current as high as 6A, not regulated output (will dim with battery depletion) and A LOT of heat.
The C8 handles the heat quite well, but don’t expect to use it for more than 10min because it will burn your skin…
The other problem is over discharging the battery. If you use a non protected battery, you’ll likely harm it quickly.
I have a B158B with a XP-G2 and no driver but I only use it for short burst of less than 2 minutes. I regularly check the battery voltage in order to not harm it.
Your best option is to swap the existing driver for a Biscotti-based one or to load the Biscotti firmware in your driver.
Then you’ll be able to choose the 100% mode only in the configuration
