I have been using a C8F with my AR for raccoons and short range coyotes. For my longer range stuff, bolt guns and magnified optics I use an XHP-50.2 that I built that is well focused and driven pretty hard off of 2 26350 cells. Something like this new L21 might be and interesting replacement for that kind of work. Last time I checked, we can’t use real night vision in IL also no suppressors, so the big 6mm-284 does not get used often at night and I can only light out to about 400 yards and still use my 8x32x optics. Plus the darn thing goes so fast that I am not sure what a suppressor would really do for it.
Just read this topic, in fact I’ve just received this new light the other day, and I would like to improve the beam on it, because now it’s got like two donuts , I would prefer only one ,more concentrated , do you think this idea would be feasible with the gasket included ? I mean raising the reflector ? Thanks
Which led version do you have? The factory messed up the focus which is why the focus hasn’t been very good. I got the correct size gasket made for the Osram chips, it’s only the SFT40 that needs adjusting, but I’m personally quite happy with it since the large corona helps out hunting to track an animal, if it runs after the first shot. It still could be worth correcting though
Sorry ,my fault, is the second one, so not for the culpm1, is the square one, at the beginning I haven’t seen the square inside the outer ring (sleepy lol); does that mean that buying new culpm1 gasket might improve the beam ?
It has the same thickness, but it won’t fit since it’s too small. No improvement. I just a play and increasing the thickness makes it much better, but haven’t yet found the correct thickness
I still wonder, how did barracuda be able have such a tight spot beam with a xplhi ,and others makers still not being able to simulate it? Maybe the end of the reflector where the led is sitting? Or what else could be? I still have others lights with different LEDs and none the same; at the beginning, there was blame that LEDs weren’t dedomed ,but now ,same issue
