Dear All,
Maybe you will be interested in this headlight review :smiling_imp:
You can find a full, more detailed review on my flashlight blog (with google translator in lower left corner).
In this short article I will show you the Convoy H1 headlight.
Brand: Convoy
Model: H1
Emitter: Cree XM-L2
Luminous Flux: 1046 LM
Max Beam Intensity: 3861 cd (I measured)
Switch: electronic
Battery: 18650 (only)
Modes: 5 (low, mid, high, turbo, strobe)
Lens: AR coated hardened glass
Reflector: OP
Waterproof: IPX6
Get a headlight in a familiar white cardboard box (as colored edition S2+). We do not get a lot of accessories. We get a simple headband and a clip.
There are three main parts can be disassembled.
The head contains the 21mm diameter driver. Unfortunately, I did not release the metal closure in front of the reflector and above the switch.
The body is the usual thick tube, the thread towards the head and towards the tailcap is not the same.
The tailcap is a simple structure, unfortunately there is no space for magnets.
Large enough. Not just big, itās heavy: 69,9g
From left to right: AA battery, NCR18650B, Armytek Tiara A1 Pro, Nitecore HC30, Skilhunt H03, Convoy H1, Armytek Wizard Pro
The above picture shows the biggest problem. The headband. Unfortunately, this is weak, it does not keep the lamp safe when we move. It is recommended to replace it with a stronger 3 strap version.
Apparently, there is no heat protection and no timed step down in the turbo mode. Safe to use in high mode!
Also, everyone is interested in beamshot pictures:
In ascending order: Convoy H1 high mode, Skilhunt H03 (the highest) turbo, Armytek Tiara A1 (the highest) turbo, Nitecore HC65 turbo, Convoy H1 turbo, Nitecore HC30 turbo, Armytek Wizard Pro (the highest) turbo mode.
Heavy weight is good for draining heat. Unfortunately, the headband is weak for this weight. The clip works well. When used as a (angled)flashlight, the Convoy H1 performs very well. If you use it as a headlight, you need a stronger headband. You also need to be careful because your turbo burns your head if you touch it!
You can buy @ GearBest
