There are various different ways, I use a small chefs blow torch under the MCPCB at a fair distance to warm it up slowly, then bring the torch closer whilst watching the LED closely until I see the solder melt. Seem to have had good results so far, maybe done 40 or so reflows with this method. Matt Smith off here has a good video on YouTube explaining how to do it - he explains with the skillet method https://youtu.be/B3F68ubfBkk
Thanks. It looks like the m21b fits the bill. I like the 21700 form factor. For a thrower, I don’t mind it being larger than pocketable size…as long as it fits in my car’s glove box.
Now to find one with osram led. That 2.3k lumen at 500m+ is what I’m looking for.
Nice work. Would you be able to share the info as a spreadsheet file, like Google Docs or something similar? Just in case it’s possible. Thanks in advance!
I think it’ll also be good if people may be able to contribute.
(eg. S2+ now has LH351D option ; T2 now has Nichia option, and the new ones are 4-modes (but no strobe) instead of 3-modes (with strobe), etc…)
Thanks. It’s cool how the emitter gets sucked in to fit perfectly. That said, this is probably where I draw the line. I’d rather have someone else do it for me. I’m a city boy without a workshop. I do have a soldering gun and a butane blowtorch (for creme brulee) but soldering or reflowing emitters is a bit too much for me. Maybe somewhere down the road I can entertain it.
If compactness is less of a requirement, there are many benefits to going a bit larger. Better heat capacity/dissipation and the larger optic/reflector means you can use a lower power level to achieve the same intensity. The 21700 version of the C8+ should get a look (M21A). This would likely hit ~160kcd with boost HX
Bought 2 of these set’s back in the day…then re-threaded the BLF A6 battery tube to fit the X6… culd not stand the stock battery tube…BLF Kronos X6/X5 GB - Group Buy now closed.
Sorry, to clarify I was walking around for a few hours and shining it at things intermittently. Battery was still at 4v and even tried a different battery with no luck.
Any information on using Luminus SBT90-R (the "red brother" of SBT90.2)? Will that be interesting to you? With a proper driver it should be possible to push it close to 2,000lm of red light. The only downside is the price of approx. $ 57.00 per each. :-(
Hello, can anyone please explain me the difference beetween 4 modes and 12 groups driver (one that in S12, S21A and so on). My question is there stabilized work in 12 groups driver like in 4 modes, so the brightness won’t slowly decrease during battery drain). I’m got S12 with 4 modes and its surely stabilized, but I don’t sure about 12 groups).
