Hey Simon, what kind of driver is the 12 groups 8A one again?
Is it a buck driver?
Linear. Uses MOSFETs operating in linear region to achieve regulation, sensing current through a sense resistor.
Hi Simon,
When will you have Convoy M21A KW CSLPM1.TG with 5000k?
I believe the question is whether there is an Osram CSLPM1.TG with 5000k color temperature — quick search on Google, I notice there is a CSLPM1.TG 5400k being sold, but haven’t seen 5000k yet.
Other question may be if that color temperature may be easily obtained at a “volume price”, otherwise it will probably cost much more if ordering less quantity.
With that said, I’m also interested in a more “neutral-white” CSLPM1.TG flashlight if it’s available…
I’m pretty sure the lowest CCT they come in is that 5400K cslpm1. The cslnm1 is 6000K or above.
I will be happy KW CSLPM1.TG fcbB46 5400K.
what LED for M1 do you need? I can create a temporary link.
I’ve got M21C-U. Shorter and perfectly balanced due to holding position.
The only complaint i have is the ramping curve, very fast at low outputs and slooooow on higher. I have a feeling it should be oposite.
I don’t have M26, don’t like 26650...
M21C-U is a bit shorter due to missing tail switch.
I was talking about sst40 5000k but i think I’ll go with c8+ finally. Ty!
Hey Simon,
When will you have M21A silver body? Are you planning to offer KW CSLPM1.TG 5400K?
My head was spinning with all of the Osram options now available at Convoy's AliExpress Store. Thankfully Simon provides bin codes for each, so I dug into the datasheets to compile everything. Hope this is helpful. Feedback is appreciated!
Part Number |
CCT | Chromacity | Radiating Area | Flux | Voltage | Current | Link |
Convoy |
KW CSLNM1.TG | Cold White | ebxD46 | 1.03mm x 1.03mm |
315 - 355lm (Bin: 6N) |
2.75Vmin / 3.00Vmax (Bin: 15) |
40 - 3000mA | Convoy AliExpress |
KW CSLPM1.TG | Cold White | ebxD46 | 1.59mm x 1.25mm |
450 - 500lm (Bin: 5P) |
40 - 5000mA | Convoy AliExpress |
KW CULPM1.TG | Cold White | fcbB46 | 1.59mm x 1.25mm |
1690 - 1900lm (Bin: 8RF) |
3.25Vmin / 3.50Vmax (Bin: B5) |
100 - 6600mA | Convoy AliExpress |
KR CSLNM1.23 |
Red 625nm pk 612 - 616nm dom (Bin: 2) |
1.00mm x 1.00mm |
140 - 159lm (Bin: 7L) |
1.95Vmin / 2.35Vtyp / 2.55Vmax |
40 - 2500mA | Convoy AliExpress | |
KP CSLNM1.F1 |
Pure Green 560nm dom |
Group A | 1.03mm x 1.03mm |
500 - 560lm (Bin: 6P) |
2.75Vmin / 3.0Vtyp / 3.5Vmax |
KP CSLPM1.F1 |
Pure Green 520nm peak / 560nm dom |
Group A | 1.55mm x 1.24mm |
630 - 710lm (Bin: 8P) |
Emisar / Noctigon | |||||||
(W1) CSLNM1.TG | Cold White | ebvF46 | 1.03mm x 1.03mm |
40 - 3000mA | Intl Outdoor |
(W2) CSLPM1.TG | Cold White | 1.59mm x 1.25mm | 2.75Vmin / 3.0Vtyp / 3.5Vmax |
40 - 5000mA |
Noctigon K1 / KR1 or by request (Click Intl Outdoor link above) |
(W1) CSLNM1.23 | Red |
1.00mm x 1.00mm | 1.95Vmin / 2.35Vtyp / 2.55Vmax |
40 - 2500mA |
(W1) CSLNM1.F1 | Green |
1.03mm x 1.03mm | 2.75Vmin / 3.0Vtyp / 3.5Vmax |
40 - 3000mA |
Notes:
Blanks indicate no information available
N binned at 1000 mA ; P binned at 1400mA ; U binned at 6000mA
All are 3030 footprint except KW CULPM1.TG which is 4040
Viewing Angle is 120 Degrees
Cathode is marked on all except CSLNM1.23 which has anode marked
This is awesome nightwalker!!!
Anyone has a picture of all the new Convoys like this:
I decided to go for one S21B (most compact, with good enough throw) and one L21A (biggest for best throw) Osram. So will pass both C8+ and M21A (as some consider as the only real pocket thrower).
Anyone have a rough idea what kind of cd we can expect from the S21B with CSLPM1?
where did you get the L21A from?
Is it special order to Simon maybe ?
on his AE store only seen L21A with XHP70.2 , XHP35 HI , SST40.
40kcd is a good estimate. +/- 15%
