A video of this driver’s operation would be great
I agree , I agree ,I agree... The double click to turbo is a horrible idea .Double click to strobe would just be worse. Strobe just needs to quietly go away and never return .A nice slow beacon hidden is what all the cool kids are using these days .
+1, single click ON, single click OFF, press&hold for switching modes. Only way to go... Dbl click is freed up, use as you like, but generally turbo/max is used.
For the SST-40 driver description's list of weirdnesses, let me also add that it is funny to see good old strobe selected as default 3rd mode annoyance, and then there is a “100% brightness” setting which I do not find a good reason for.
First of all let me say the driver at least lacks one more mode: it should have 4 modes, with the newer 4th mode being the same as the 3rd in the above chart, and the newer 3rd mode having a default setting of ≈200mA or so and being also ramping adjustable.
The chart sucks and the driver's stock firmware sucks. I would prefer the LD-25's firmware in this newer SST-40 driver.
Simon, you mentioned being able to get the SST-20 in a rosy 4000K bin (FA1, FA4, FD1 or FD4). How’s that going?
For the SST-40 driver description’s list of weirdnesses, let me also add that it is funny to see good old strobe selected as default 3rd mode annoyance, and then there is a “100% brightness” setting which I do not find a good reason for.
The chart sucks and the driver’s stock firmware sucks. I would prefer the LD-25’s firmware in this newer SST-40 driver.
I’ve ordered 2 of these drivers for my S11 hosts, but I’m sure I’m going to replace them with a Biscotti driver and 17 mm adapter. This… is a weird UI.
Since Sofirn SP33 looks quite similar to Convoy S11, both using XHP50.2, 26650 and ATR, it will be interesting to see what brand that has the highest sustainable output with less heat.
IMO, I would go with the S11.
Having NW color options makes it much more appealing.
It will also probably have the highest sustainable output since it uses bridged springs compared to a steel spring in the SP33.
It’s also a bit heavier.
I may be wrong though.
CK though has custom OSHPark boards to mod the SP33 with, so running a 3V XHP50.2, or other NW 3V LED's is nice with Anduril or NarsilM
I got the driver boards on order and a 2nd SP33 on order now.
The S11 is pretty hefty - I can weigh it tonight.
Yeah, I’ve seen your review.
When I saw that bypass, I’m always sad that someone had to solder a wire to hard to solder to steel wire, even when gold plated.
I do wonder if I could convince Simon to use BeCu springs in his lights, like the C8+ SST-40 and S11, and even the Convoy L6.
On another note, I shipped the springs orders today, which included yours, but went after 5PM, so will be sent tomorrow.
That’d be a good idea - some good double springs, or good quality ones. And thanks; they’ll arrive when they arrive
Simon, please consider a stronger clip in your newer designs. For me, the thinner metals clips are not that secure and bend over time. Thanks.
Another idea - have the clip only fit on in one spot if it’s only a tail switch; line up with the logo. I’ve got the Desert Tan S2+ that came with the black clip, but it still slides around a bit.
Perhaps something like the way Olight does it? Basically “removing” the groove except for where the clip goes.
LD25 can not output such big current,
i will ask LDCH if he can produce suitable driver for SST40 and the same current setting as LD25
sorry,i can not find these tints
Simon, are you going to make a 21700 light with an integrated shelf like the S3?
sorry,i can not find [rosy SST-20] tints
Thanks for the update. I was waiting to buy more SST-20s to see if you were getting them.
Can you put the C8 with SST-20 in the store? I want to be able to link to it in my recommendation list - explaining that it’s possible to special order is too complicated for the list.
I've been lingering with the idea of increasing the current output of an LD-25 via sense resistor modification. Adding an R020 would raise its maximum current to 4.5A, for example. I know I would need to somehow manage extra cooling for the onboard AON7520 MOSFET to avoid ;-) fireworks.
This newer SST-40 driver would thank a better interface. Luckily with a current sense adjustment it can be a no qualms better fit for lower current emitters. For example, an R020 plus 3x R050s is 4.4A at 40mV of sense voltage; an R010 plus an R050 is 4.8A.
Overall I like LDCH's drivers. I would prefer a newer much more powerful LD-29 style buck driver. Thrice (multiply by three) its maximum current drive please. I recently tried to mod one for higher output but it blew up, the onboard XC9220/XC9221 buck controller is unsuitable for using more powerful (higher input capacitance) MOSFETs, it cannot drive them.
Cheers
(Pic removed)
Inkidu, you posted a 7.5 Mb picture, it took forever to load, resizing it is more reader-friendly
