Surprise Surprise, Lishen makes a battery that doesn’t fit. Chinese battery manufacturer making batteries that are too fat and too long I can only assume to boost their numbers.
Help me, please
I have an idea, what is going on here, but I want to know your opinion:
C8+ and S2+ with updated firmware, 8*7135. Sometimes they turn the brightness to a lower level. It doesn’t look like bright enough to begin with.
What can be the reason?
I suspect the battery, as it happens with the 3400mAh Intl-Outdoor batteries (2600mAh from them or salvaged battery does not do this), but I am interested in your idea as you know how the firmware works.
Following products will be available on 2019/5/27
20mm driver for SST40 (output current 6A)
22mm driver for SST40 (output current 6A)
S21A with SST40
M21A with SST40
L21A with SST40
L21A host
gray S11 with SST40 (SMO)
gray S11 with XHP50.2(SMO)
gray S11 host
Following products are in order or design
L21A with XHP35 HI LED ( output current is 2.3A) (Lighting distance above 800meters)
21700 flashlight with 3LED in one board and 6A 22mm driver
4*18650 flashlight with single XHP70.2 LED
3*21700 flashlight with single XHP70.2 LED
SST40 5000K LED
clear S11
Titanium alloy AA flashlight
About copper flashlight, due to the difficulty in finding a cleaning plant, the date is uncertain
@Simon
Does it mean no 18650 flashlight with 4 LED in one board ?
Doesn’t the S21A already be a 21700 flashlight that can fit 3LED in one board (Carclo 20mm triple + Noctigon 20mm triple MCPCB) ? If so, why another one instead of something different to fulfill different needs ?
There is nothing new host-wise since long for 18650/18350 users. I insist, a 18650 quad would be welcomed.
