With this light I wanted a “wall of light”; a whole lot of lumens in a mid-sized beam that has a bit of throw. I chose dedomed XP-L V6 1A for their high output and high die luminance. I chose narrow TIR optics from LEDDNA because I have this optic in my S2+ and I like the beam; it has a larger beam than the S2 reflector, and with similar beam lux.
Pictured with an EE X6 and S2+ with TIR.
I am using a 2s setup. A group of 4x parallel XPL in series with a group of 3x parallel XPL. This means the 3x parallel group is receiving 1.333x more current than the 4x parallel group, but I’m willing to live with this bit of asymmetry. The 2s setup results in higher performance than an equivalent 1s setup because there is less voltage drop in the circuit resistances. Also, wiring the two cells in the L2 in parallel would have been difficult.
Picture taken through “solar viewing” glasses. The current asymmetry is not enough to see here.
The driver is a FET driver from mtnelectronics with a FET-only version of Bistro. The switch is a forward clicky. I could get used to this, but I think I will look for a reverse clicky to put in there.
I made an Al spacer using a lathe. It is a large chunk of Al (132g of Al) which absorbs a lot of heat and allows the light to be used on high for ~100sec before it gets too hot. I used 20AWG wire from the driver to the top of the spacer and 22AWG for wiring between the LEDs.
The TIR optics I received from LEDDNA were different from the optics I received from a previous order several months ago, even though I ordered the same part. The new optics are a bit taller (by 1-2mm) and the center part is just a flat window to the LED instead of a convex type lens like in the previous version. I am still happy with the beam, though. It is a large even hotspot with a sort of narrow spill.
On the left is the 7xXPL L2. On the right is the EE X6 with dedomed XPL V6 1A. This is just to illustrate the relative beam sizes; lights were not on max.
At turn on, estimated from a semi-calibrated ceiling bounce test, it does 8660 lumens. Using two Liitokala 26650s. Current is around 15A measured using a 10mOhm shunt resistor bypassing the tailcap.
At 30 seconds, it does 145.3 Kcd.
Thanks for looking!
