I’ve bought lots of Convoy lights over the years and sometimes direct from Simon via his Aliexpress store, although never really been a fan of Aliexpress as they didn’t use to accept PayPal.
However I ordered up an L21a with the CULPM1.TG LED from the Aliexpress store recently. Shipping has been quite quick, although some weird things going on with Tax/Vat charges and the like (not really for this thread).
Anyhow the light has just arrived.
Hoping this will eventually turn into a positive report but feeling underwhelmed as of right now.
Minor things that might nor normally bother me, but one major thing that has just made these worse somehow:
- Lens filthy with spots all over it
- No spares such as O-rings and the like. Just the torch and nothing else
- Shards of aluminium in the threads
Biggest issue WTF has gone on with the driver??? Over complicated piece of sh*t!
Inserted a fresh Samsgun 40T and turned it on - nothing. Then a buzzing flashing mode, then low, then steps through brightness modes, then strobe.
Have tried reprogramming it, but honestly haven’t got a clue how to do it. The instructions are awful.
And I have no idea what the light is telling me once you get it into a programming mode. I have no idea what mode it is on now or how to know which mode to set it too. All it does is flash in a way that is impossible to count or tell what is going on.
As of right now the flashlight is total junk and unusable.
—- an utter waste of money.
From Simon’s store:
12 groups:
1.click the switch to turn the flashlight on/off,tap the switch to select mode
2.if flashlight is turned on,tap the switch 20 times quickly to enter into config mode.(On a visual interface,as long as you click on an option, it means that the option is selected. The flashlight has no visual interface. It flashes to represent an option, and “tap the switch in the flashing process” means to select the option.)
Option 1 (normal-flash 1 time + buzz-flash): tap the switch to enter into sub-option to select the mode group,If the user has no operation, the config mode will enter option 2.
——————-sub-option 1.1 (normal-flash 1 time) : tap the switch to select mode group 1 (0.1, 1, 10, 35, 100%, strobe, biking, battery-check)
——————-sub-option 1.2 (normal-flash 2 times) : tap the switch to select mode group 2 (0.1, 1, 10, 35, 100%)
——————-sub-option 1.3 (normal-flash 3 times) : tap the switch to select mode group 3 (100, 35, 10, 1, 0.1%)
——————-sub-option 1.4 (normal-flash 4 times) : tap the switch to select mode group 4 (1, 20, 100%, strobe, biking, battery-check, SOS)
——————-sub-option 1.5 (normal-flash 5 times) : tap the switch to select mode group 5 (1, 20, 100%)
——————-sub-option 1.6 (normal-flash 6 times) : tap the switch to select mode group 6 (100, 20, 1%)
——————-sub-option 1.7 (normal-flash 7 times) : tap the switch to select mode group 7 (0.1, 1, 10, 50, strobe, biking, battery-check, SOS)
——————-sub-option 1.8 (normal-flash 8 times) : tap the switch to select mode group 8(0.1, 1, 10, 50)
——————-sub-option 1.9 (normal-flash 9 times) : tap the switch to select mode group 9 (50, 10, 1, 0.1)
——————-sub-option 1.10 (normal-flash 10 times) : tap the switch to select mode group 10 (1, 10, 35, 100)
——————-sub-option 1.11 (normal-flash 11 times) : tap the switch to select mode group 11 (100, 20, strobe)
——————-sub-option 1.12 (normal-flash 12 times) : tap the switch to select mode group 12(100% only)
Option 2 (normal-flash 2 times + buzz-flash): tap the switch to active the mode memory or inactive it,If the user has no operation,flashlight will enter into the last mode.
