Convoy L6 LED Flashlight - 5,200 lumens, Cool White - $39
MSRP: $80
Sales is as is!
Includes:
The Convoy L6 is a powerful, high-output, dual-26650 battery flashlight known for offering exceptional brightness and solid build quality at a budget-friendly price.
Key Specifications:
  • Brightness: Max output 5,200 lumens
  • Battery: Powered by two unprotected 26650 lithium-ion batteries
  • Dimensions: Length of 255mm, head diameter of 75mm, and a tube diameter of 35mm.
  • Weight: Approximately 550g (without batteries).
  • Water Resistance: IPX6 or IPX8 rated depending on production batch/spec specifications.
Design and Features:
  • Reflector: Utilizes large aluminum alloy smooth reflector
  • Heat Management: Features a large integrated head and deep cooling fins that act as an efficient heat sink for extended high-output runtimes.
  • Build: Rugged black anodized aluminum body with aggressive knurling for secure grip.
  • User Interface: Tail Switch: A physical forward-clicky mechanical tail switch handles main power (on/off) and momentary activation.
  • Side Switch: An electronic side switch controls mode changes and special functions.
  • Modes: Standard spacing includes 1%, 10%, 40%, and 100% brightness levels with mode memory.Strobe: Double-clicking the side switch from any mode activates the strobe function
