Code: BGNL6 (Must select P2-3C - 5000K color temperature)
- Order Subtotal: US$71.57
- Coupon Discount: US$25.57
- Grand Total:US$46.00
Cheapest deal on this was $39.99
Affiliate link: https://www.banggood.com/Convoy-New-L6-XHP70_2-4300lm-5000mAh-Powerful-Super-Birght-Long-Range-Strong-LED-Flashlight-High-Lumen-26650-p-1414040.html?p=R4240016492493201711&custlinkid=181231
Specification:
Product name: | Convoy L6 XHP70 3800LM LED Flashlight |
Brand: | Convoy |
Model: | L6 |
Emitter Type: | XHP70 (soldered on 20mm copper plate) |
Emitter BIN: | N4-1C,N2-3A,N4-5C,N2-7A |
Light temperature: | 6000k(white light),5000k (neutral white),4000K,3000K |
Material: | Hard-anodlized Aluminum alloy |
Mode: | Low 50mA,Mid 200mA,High 1700mA,Turbo 5200mA,Strobe |
Battery Configurations: | 2 x 26650 6A protected battery(not included) |
Switch Type: | clicky |
Switch Location: | Tail switch for turn on and off, body switch for change modes and double click the button the light will strobe. |
Max Output: | 3800lumens |
Range: | 200-500meters |
Reflector: | Orange peel reflector 67.8mm x 48.2mm(diameter x height) |
Lens: | Ar-coated lens |
Waterproof: | IPX-8 waterproof 2 meters |
Color: | black |
Weight: | 255mm x 75mm x 35mm(length x head x body diameter) |
Size: | 550g without battery |
Note:
1.Please take out of the battery when the flashlight no use for long time.
2.When setting the tactical ring please take out of the ring on the flashlight.
3.Please use 2 x 26650 6A protected battery to confirm the safety of the flashlight.
4.When carry the flashlight in the backpack,please loose the tail cap in case of wrong click to the button.
Package included:
1 x Convoy L6 XHP70 3800LM LED Flashlight
1 x Tactical ring
https://www.youtube.com/embed/zvItZBCn64E
