Smaller reflectors usually exacerbate crappy beams. Piss-yellow coronas on Crees, nasty coronas with other chips.
Unless you really keep down the LED : reflector ratio as small as possible, that’s a given.
But with teenytiny chips and teeniertinier surface area, you’re cranking up the current density, killing efficiency.
Take one of those CSI-NY chips and stick it into a GT reflector, and you’ll get a crisp beam.
Big chip like a ’351 in a small S2+ (or FC11, or SC32pro, or whatever) reflector, and counterintuitively you get a pretty good beam, especially if the reflector’s OP and not SMO. Not much axial tint-shift to ruin it with a nasty corona. I’ve had pretty good beams overall.
There are not many complaints about color shiftin in the S2+.
‘Arlo’ is not looking for a thrower but simply more throw than Olight I5T at 19lm setting.
If you have true 3000mAh battery, with 6x7135 driver (2,1A) at 10% setting we’re talking about 10 hours of runtime, maybe even slightly more.
One more thing - Simon from Convoy (active on this forum as well) is quite elastic when it comes to flashlight configuration. You may ask him to install LH351D emitter instead of SST20 as it’s more efficient and you like the modes of the SST20 original driver.
The LH351D is a fine emitter choice but I love the SST-20 4000k. Just the best looking LED output for my eyes. In my S2+ the SST-20 gives a fairly throwy but well balanced beam. Its a solid do-all light.
Aside from a rewrapped recycled Crapfire cell, any decent cell is fine. VTCs vs 30Q vs HGs vs MJs… all good cells, but unless you’re dropping ’em into a MT09R or something, they’ll all work fine.
“Oh, but I can wring out 6.3A from my VTC6 instead of 6.1A from a 30Q…” Big deal. Difference in current is negligible, brightness even more negligible. At some point you’d just be pushing out more heat than light, eg, 30% more heat for maybe 5% more light. Visually indistinguishable.
In a S2+ or any normal light that won’t set your house on fire, any decent and quality cell will be fine. For me, 30Qs are my go-to cells. And yeah, only in my MT09R do I have some VTCs, and that’s just because they’re supposta have less internal resistance and thus wouldn’t heat up internally as much if turboed.
Convoy sells good batteries on Aliexpress as well, sometimes even as a bundle with a flashlight (and they have top end 18650 cells like Sanyo 18650GA3500mAh, LG MJ1 or Samsung 35E - they’re equally good). Sadly there’s no bundle with SST20 based S2+ listed (there is with LH351D but it has a different driver) but Simon from Convoy is quite elastic, I think you should ask him (here or just use “contasct seller” form on Aliexpress) wether he could sell you a bundle of S2+ SST20 with 18650 battery.
Once again - would you prefer a SST20 emitter which is less bright but offers more concentrated beam, or LH351D which is brighter but more floody?
So we have a Convoy S2+ with 6x7135 driver:
You have to decide wether you want to stay with SST20 emitter or go for brighter (with the same power consumption and runtime) LH351D. If you decide to swap - that’s the first thing to ask Simon/Convoy. Second thing to ask for - the battery bundle.
I think I will stick with the SST20 with 6x7135 driver. Thanks again for all the information, will have a look at the batteries on his site and can make my choices from there.
I've tried the Convoy S2+ SST20, but haven't tried the Convoy S2+ LH351D variant yet..
Posting some beamshots of S2+ with SST20....
I have the Wurkkos FC11 with LH351D also in warm color temperature, although it's not exactly the same flashlight as the S2+, I think it's a bit fairly close in terms of size as the S2+
(although S2+ reflector and FC11 reflector are slightly different, which can also affect the beam throw/focus and floodiness)
Some beamshots for reference (taken at around the same distance from the opposite wall, using the same camera settings -- the same camera is always used for taking these shots and manually set to the same setting; the distance may slightly change since sometimes I stand a little bit to the left or right and hold the flashlights with my hands only):
Convoy S2+ with SST20 (and also XPL-Hi), all are "7135x8" variants,LED & color temperatures as labeled:
Wurkkos FC11 (Samsung LH351D) beamshots
I think it's easy to see that the SST20 has a much smaller hotspot than the LH351D... although the reflector of the different flashlight has a slight effect too..
There’s nothing to look at - they’re the best 18650 batteries on the market right now. It’s the matter of asking Convoy to make a bundle with S2+ on SST20 so you won;t have to pay for shipping twice (also shipping a battery in a flashlight will cause less legal issues).
If you choose to go SST-20 route, may I suggest you also get a 45º TIR optics to try. SST-20, even with OP reflector is a bit too throwy for me to use as a general-purpose light.
With this TIR and SST-20 4000K with 6x7135 the light is good for 20-30m.
Exactly - Convoy is not a battery store, they sell flashlights. But’s it’s a reputable store and their flashlights, emitters and batteries are legit (so far).
Simon is a super cool dude without a doubt. REALLY gives a about the led light biz he is in 100%… and almost always asks me “why” when I try to do something stuupid’ - Convoy lights are as legit as they come.
