I am going to buy a Convoy S2+ and I have narrowed it down to two.
The LH351D
and
The SST20
I’m pretty clueless in regards to the technical aspects, but after reading some previous topics, I have decided that I will go with 2700k in whichever one I decide to get. So I’m just left wondering about the driver.
So to all the experts, what are the pro/cons between the LH351D and SST20?
SST20 will have more focused beam with better throw, LH351D is going to be more floody. But I wouldn’t go with 2700K personally, I think it’s too yellow/orange. I think 3500K or 4000K with high CRI will give you the highest quality light.
LH351D is rather floody.
SST20 will give a better throw.
At 2700k both have a great tint and cri.
A driver with x*7135 will give less current, but is mod friendly.
If you choose a flashlight with LH351D, take a driver with 12 groups. You will be able to adjust the number of modes to your preferences. Additionally, this driver has thermal protection.
SST-20 has a smaller LES (light emitting surface?) but apparently the CRI is even higher than the LH351D. LH351D in 2700k is a nice high CRI tint compared to Cree 3000k. Yet to own a torch with 2700K SST-20.
You may get a smaller hotspot with the smaller LED and it might heat up more on high mode.
7135*6 would probably be a good choice, comparing two XM-L2 S2+s the brightness looks similar to 7135*8 but it uses 700mA less and runs cooler.
I forgot about one thing - LH351D is much brighter. At 3A it puts out like 1200lm meanwhile high CRI SST20 just 720lm. And S2+ with LH351D comes with 5A driver for roughly 1800lm (and quite a lot of heat altough it is temperature regulated - it will reduce brightness to avoid overheating) output meanwhile SST20 one with 6x7135 driver will make just ~550lm (while staying relatively cool). Medium mode in the LH351D version should be about as bright as SST20 at full power! So we’re talking about two different flashlights from the brightness standpoint as well.
I was siding with the SST20 for more throw, but now that you say the LH315D is much brighter, I’m torn.
For reference, mainly I want it for walking my dog. I got a present of an olight I5T and use that on low (15 lumens), while it’s enough light(more floody in my inexpert opinion), I would prefer something with a little more throw.
Maybe the middle setting on the SST20 or LH315D would be more than enough for my needs, regardless of how bright?
1200lm at 3A? And 1800lm at 5A?
I guess you took this data from the Texas_Ace test.
But he tested the cri70 version. Simon has the cri90 leds.
Looking at the maukka test of the cri90 version at 3A it is <1000lm, and at 5A <1300lm.
In addition, both tested LEDs are 5000k, and 2700k will significantly lower these lumens.
I’ve already ordered the Sofirn SC01 which is SST20 @4000k, so I would like something warmer to try out, the Convoy SST20 only has 2700k and not a 3500k option, whereas the the Convoy LH315D has the 3500k option. So maybe the 3500k would be a nicer beam…
LH351D has two middle settings: 3% and 30. If those are accurate then it should put out 75lm at 3 and and about 600lm at 30%.
The SST20 version it’s more complicated due to multiple groups of different modes that can be selected. But if you’re going to choose 6x7135 driver (max 2,1A) the 10, 20 and 35% middle modes (available in diffrent groups) should net you 72lm, 145lm or 230lm respectively. Those will go higher by 20-25% if you are going to choose 8x7135 version of the driver.
Thanks very much phantom23. Those mid lumens suit me perfectly, I’d probably be mainly going for the 72lm, would you have a runtime in relation to those lumens?
“Throw” and “S2+” really shouldn’t be used in the same sentence. Tubelights are great for flood and intermediate range. You want throw, get a thrower. You’ll be happier that way.
I did runtime and shoebox lumens testing with a 7135*8 2700k SST20 S2+
Here’s my estimate based on the data sheet and my 7135*8 example:
The SST20 with SMO is one of the throwier S2+ models and with the 2700k LED it’s one of the least efficient and IMO useful models. I like mine for the tint but don’t use it for much serious use as the beam is not very useful and the runtime is poor, even in comparison to other 7135*8/7135*6 models. I assume this inefficiency would transfer to 7135*6 models as well.
I have runtimes for a few different S2+ lights at the link below. The 7135*8 SST20 2700k is about as bright as the 7135*6 XP-L HI 5000k model but has about 60% of the runtime.
