I haven’t been here in a while. I got several S2 / S2+ a few years ago when I was taking apart battery packs I got at trade shows and had a bunch of 18650 batteries.
I’ve taken apart a couple that say S2+ on the barrel. The LED is mounted on a ‘pill’ held in place above the battery with a retaining ring. And the orange peel cone and glass all come out the back once I remove that retaining ring.
I took apart 1 last night that says S2. This one had a silver ring at the front of the flashlight. Turns out the cone and glass come off that way. After removing the retaining ring, I see that the circuit board is wired to the LED with red and blue wires. And the LED is mounted to the barrel? With 2 holes for the red / blue wires coming through a disk that is part of the barrel (it was machined on both sides of the disk? vs. the others I am used to where it’s a tube when things are removed.
Assembling things, I had a problem getting the retaining ring’s threads to line up. As I tightened, I notice the circuit board sometimes turning / sometimes not. That added twists to the wires to the LED and 1 wire broke.
Some questions:
- is the pill design typical for S2+ and this wiring through the disk common for the S2?
All the other flashlights I have (and most I haven’t even used) say S2+ and do NOT have that silver ring. So I think / hope they use the pill design.
How often do you take your flashlights apart?
How do you clean things? I’ve been using Deoxit 100% spray. And recently got some nooxid grease that I put on threads and battery contacts / springs when putting it back together.
I could solder a new wire, but putting it back together, I would likely have the same issue of the circuit board turning / twisting wires.
is that a bit of a design flaw / that’s why they changed things in the S2+?
Does this S2 have any value for parts? List it here? Ebay? Any idea what I’d get for it?
I just saw this site in my notes.
https://www.mtnelectronics.com/index.php?route=product/product&product_id=101&search=s2
You can see that disk with 2 holes in 1 view. Does that come out? I can’t tell from that view. Did I disassemble it wrong?
I like how these are small and bright and when I bought these pre-covid, they were cheap ($15 or so?). I still have a load of 18650 battieres.
is this still a good inexpensive flashlight? If you were looking for a single 18650 light that you will likely lose it : ) (I’ve lost a couple) what would you get?
and from where?
THANKS!
