Hi!
I am currently looking, as mentioned in my introduction thread, for 2 things:
- A UV light - for no particular application, should be a decent compromise between being somewhat powerful and okayish battery life, and not too bulky. Hard to spec it any more accurately since I really don’t know what I want to use it for. I just want to have one.
- A compact but decently bright white light to keep in my backpack, ideally high CRI neutral (love 90+ CRI 4000K emitters).
So I had the idea to basically buy the same light - but twice. Convoy S2+ UV in purple (+ purple 18350 tube) and a S2+ in gray with a 519A emitter, again 18350. Figured it’d look nice to have two lights, identical apart from the color and LED.
Does anyone here have the S2+ UV and has any experience with it? Is it worth getting the UV filter for it (I guess yes)? Shop page says 1A current (1 mode only), and the 16350s Convoy sells should be ~1 Ah real-world, so 1 hour runtime - sounds plenty to me.
As for the “regular” one - if I want a neutral, high CRI tint, I guess the 519A is the best emitter out of the ones offered in the S2+ for my needs? Battery life will probably be terrible when run at higher powers (drivers allow up to 5A, with a 18350 cell…), but it wouldn’t be a light I intend to use at full blast for extended periods (and I can always swap cells with the UV one once it is empty and have another full battery). If I just want it to be bright, I bring my SP33S.
And one more thing - do these clips fit the S2+ as well? I think I read they fit somewhere, but if anyone has a pic of a S2+ 18350 with it, I’d be grateful! Only found pics of it on the regular long tube. (EDIT: Found one just now, in this forum too… Had to scroll far down on Duckduckgo for it to pop up: [Review] - Convoy S2+ 519A 4500k - By Argo - this clip looks really sweet! on an 18350 tube S2+!)
2.25€ |Taschenlampe taille clip, edelstahl clip, für neue C8,M2,S3|s3 batterie|s3 radioclip bang - AliExpress
Or would you rather get the universal clip? That would open up the possibility for lanyard or magnet (not at the same time, right?
Some people said the universal one slides off easily, and it does not look as good as the screw-in, that’s why I’m not really sure.
Dropping around 70 bucks on a light I don’t need and a smallish EDC seems like a lot of money for me, so I wanted to ask here first, see what you people say before pulling the trigger!
Cheers,
moritz
