【convoy】Golden S3 available now
The sales of M21A are low, so there is no such plan for the time being.
I couldn’t hold out any longer and bought the L7. I hope Simon you will produce single piece 2-26800 tubes for the L6, L2 and L7. I think I’m going to need at least 3.
Sounds great. Fingers crossed that they can offer something similar. If I am not mistaken LEDs with converted green are the most powerful ones.
By the way, could you please check if you can test/buy the new Chinese LEDs like SFN60, SFN55.2 or SFS80? On Taobao some extremely powerful Nightwatch models have shown up. Maybe you can also offer Lishen‘s LS2170LA 4.000mAh battery in your shop? It is Lishen’s most powerful 21700 battery, close to Samsung’s 40T performance.
NS73
https://world.taobao.com/item/650487179489.htm
3x SFN60 (15.000lm, 52A on turbo from one single battery!)
NS03 Plus
https://item.taobao.com/item.htm?id=649765849422
1x SFN55.2 (7.500lm, 32A on turbo) or
1x SFS80 (1.850lm, 7,2A on turbo)
Hi Simon,
Would it be possible to add a 50, 100 mode to the 12 groups mode driver? I would like to be able to run the flashlight at a reduced output of 50% while still being able to go to 100% if needed. I think it would be useful for using throwers in real-world situations for extended periods of time, like a L21B with SFT40 as a searchlight. At 50% you should still get good throw but it will take longer before the flashlight throttles and the battery will last longer.
When will the M21D be available with GT-FC40 and SFT40? Would you produce the M21D in “Desert Tan” colour?
Sorry if this has been said and I can’t find it, but does anyone know if the new L7 can fit (non-protected) 21700 cells? Or how long of cells do fit? I know some protected 26650’s used to not fit the L6, not sure if that’s true of the L7.
Anything longer than 69mm used to not fit the L6. Simon has said it’s the same host dimensions, so guessing it’s the same
Simon can confirm
found this on youtube:
https://www.youtube.com/watch?v=2K9iDc8zn0s
this always bothered me, why in flash lights in general there is only a jumb from small numbers to the turbo or 100%, why there is nothing in the middle like 70% , (even in convoy you can't find 50% and 100% in the same group).
Why there is no groupes like (10%,30%,50%,70%,100%) or (10%,35%,70%,100%).
I hope simon looks into this and adds more variety to the groupes options, that will be great
Yes, I definitely wish there was an in between level for a slightly longer run
Interesting find today - Fenix TK15UE remote switch legoes perfectly with S2+ grey version and also works with C8, though it cannot fit well.
Some first impressions of the 3X21A SFT40 6500K (batch #1)…
What I like:
  • nice matte finish, sturdy design and flawless anodizing
  • good thermal properties, takes quite some time to get real warm
  • good driver accessibility (held by two screws) for modifications/repairs
  • price/performance ratio (best bang for the buck)
  • brand new emitter (Luminus SFT40) which offers more throw than SST40
  • beam looks pure white (no AngryBlue™ or PukeGreen™), very pleasing for coldwhite
  • beam profile offers both a long range hotspot and enough spill for surroundings, even better than the 4X18A SBT90.2
  • the flat top adapter - Simon, you are a genius for inventing this simple but awesome adapter! Finally, no more need to use button top batteries.
Some minor things I‘d like to see improved:
  • if you were able to get SFT40 5000K it would be an even nicer tint, fingers crossed that it will become available anytime soon
  • the user interface deserves some little tweaks to be just perfect (I will be happy to assist here)
  • 21700 cutouts seem to „snug fit“ a bit too well. Wide-body 21700 batteries (e.g. Molicel M50) with 22mm diameter may not fit. Standard 21700 batteries fit nicely. Sofirn‘s (Lishen) 21700 battery fits with a little friction.
  • AR coated glass is purple. For SFT40 6500K I recommend using a green AR coating to reflect the green proportion of the light (= more rosy white than greenish).
  • reflector shows some debris inside, nothing serious in terms of performance reduction but still…well…I get nitpicky again. :))
  • the reflector on my sample has a little abrasion/nick, fortunately nothing I can spot in the beam
  • springs could be factory-bypassed for less resistance in the current path
  • my flat top battery adapter of batch #1 is warped but this issue is already being taken care of. First batch adapters were made by a CNC machine whereas next batch adapters will be made by a molding machine. Simon even offered me to send two new spare adapters when they become available. Great customer service. :)
  • an illuminated and white, not grey switch (option to turn on/off via UI) would be the icing on the cake
All in all I am very pleased with this model and can recommend it.
Please do not get a false impression of the beam color. The greenish look in the reflector results from my phone camera (probably distracted by the purple AR coating). The beam on the whitewall shows no sign of greenish.
I did not get the chance to take beamshots outside yet, unfortunately.
Thanks!
Just tried the Convoy L7 now with 2pcs Liitokala Lii-40A 21700 (supposed to be a Lishen LR2170, and it worked on the L7, BUT it dented the Lii-40A (actually the Lii-40A I used has been slightly dented due to using it on an early version Fireflies PL47 which has a slightly shorter body tube), but upon getting out my Lii-40A, I think it got dented even more… :frowning:
I think a really short 21700 battery may work, but as the L7’s positive side is a “button”, it also may dent the 21700 battery.
The shortest 21700 battery I’ve checked would be the Molicell P42A (it’s very slightly shorter than Samsung 40T/30T), as the P42A is probably the only 21700 battery I can fit snugly on the Liitokala Lii-100 charger (all other 21700 batteries I’ve tested won’t fit in Lii-100, or at least not in a ‘straight’ position). I don’t have an “old” Molicell P42A that I’d like to try “denting” so I haven’t tested this yet.
(comment: Lii-40A 21700 is around 70.7mm length (got dented on L7) ; Molicell P42A is around 69.9mm length.
Regarding diameter, I tested a pair of Keeppower P2660C (protected 6000mAh 26650) on the L7 and the batteries fit snugly (slowly slides into the battery tube).
note: KP2660C diameter (26.7-26.8mm) is wider than many other 26650 batteries (usually 26.1-26.2mm diameter) ; length of KP2660C (protected 26650 is 69.0mm ; so far the L7 didn’t dent these 2x KP2660C when I checked it (I only inserted batteries, tested that the light turns on; didn’t leave it inside the L7 for long period of time)
Simon are we going to see new emitters too?
Do you mean the two modes of 50% and 100%?
If this is the case, the naked eye cannot perceive the change in brightness when switching modes.
Driver for M21D SFT40 in design now ,but no place for GT FC40 currently ,
there is black and gray M21D currently
20.5*3mm o-ring for 21700 available now,
PCB boards for connecting two batteries in series are also in production,
It looks reasonable numerically, but the naked eye cannot distinguish between 70% and 100% brightness.
I am producing 26800 battery extension tubes and PCB boards for connecting two batteries in series. Using these two accessories, I think we can use 21700 batteries,
Yes, hard to notice the difference but the reduction in amps makes a big difference in heat and runtime.
I have some problems with my VPN software, but I guess you should be referring to xhp35.2 hi led,
I used L21B to test it, but unfortunately the spot is very bad, there is a black hole in the middle, and the illuminance is also very low.
Maybe I will use M21B and match OP reflector
