Hi anyone know what size the screw and nuts are for slde clip on convoy S2+?
M2.0 x 4.5. Nuts are 1.75 mm thick.
I like how simple this conversation ended
Has it ended yet?
It did end…unless the hole is enlarged And then a thicker one would be needed
Thank you.
Perfect. I was looking for longer screws to fit one of these clips to an S21A - for some reason this is the only S or M Convoy that's too thick for the included screw's length.
Thanks. The screws snapped right in half.
I have several s2+ i bought few of those clips that came with screws and nuts, those are too thin, very undersized, i had to replace them with a bit bigger ones, do not know the size, i have a big jar of small screws/nuts, i just picked a bit bigger ones.
the hole diameter of the the clips is around 2.30mm. There’s not a lot of play, if the hole is widen it can fit up to m2.5.
Anyways I went with hex type . Couldn’t find 4.5mm so I went with m2 5mm. it’s going to pinch the rubber switcher. m2 6mm should have enough leeway for C8 and others
bolt https://www.aliexpress.com/item/2261799962114486.html
nut https://www.aliexpress.com/item/3256801919418087.html
Thank you for this, just recently messed some of these up and was wonder what size they were.
Looks like Kaidomain still sells the version with M2 hex screws:
Personally I prefer the Phillips screw version since it looks less bulky.
They also have greatly increased the variety of clips they sell (10 total now)!
I purchased this shorter one for my S2+ shorty:
This one for an AA flashlight that I modified:
And this one for my S6:
