I’d wager that neither luminance or efficiency are as high. And then there’s tint, lumen maintenance, thermal conductivity of the substrate, part to part consistency, etc.
I have similar doubts. Efficiency is almost certainly lower due to higher Vf, which also makes regulation harder.
Another problem is that the round die tends to be noticeably off-center relative to the emitter footprint in many samples I've seen online. It's ok for aspherics but will mess up the beam in a parabolic reflector.
Buck driver
4 modes ,output 0.251A - 0.821A - 2.42A - 8.05A,Their efficiency in order is 80–88–92–94,
Under the protection of temperature, The current will drop to a minimum of 2.49A
The S21D gets very hot.
It is currently available in 219B, 519A and XPL HD LED.
Which one has a high CRI (or the highest CRI) and which one stays as cool as possible?
I read the S21D can only be operated at 50% maximum otherwise it gets too hot, which limits the 12 group options.
No, the Convoy drivers don’t reduce below the high level, this causes many smaller models to get far too hot. The 8A doesn’t reduce below High, the 4X18A and 3X21A hit 80°C+
The 8A has a thermal timed stepdown, there’s no temp limit
This has been my experience as well, just to back you up. Most of them have some sort of stepdown (be it timed or thermal) between 100% and the next-highest-mode (usually 35) but they will not dip below 35 output. That’s a problem because some models can still overheat at 35% output.
On a separate topic: are there any plans for a Convoy that combines the driver of an L7 with the head of an l8? That would be my ideal affordable SBT90.2 light.
I’d love to see a hunting headlamp that uses 3x Osram LEDs: White, Green, Red with range out to 300m for the white and green, even 200m would be nice. It would be something different
