【convoy】SFT70 3000K CRI95 available
Hmmm, the datasheet mentions over 2100 lumens at 8A for N4 bin, but I’m seeing only 1760. I’m using the same 17mm 8A buck driver in both flashlights
Previous batch: 2160 is start
New batch: 1760 start
Thank you Simon.
Can you add the 26800 battery tube extensions please.
Simon if you do this by tomorrow I’ll get 2 or 3 batteries.
Did you get L21B with black gasket or white gasket?
Ok, I have many kinds of 26800 extended tube.
I will upload them together tomorrow.
Even if the upload is successful, AliExpress will take 1 to 2 days to review the link.
Which country do you live in?
I’m using the C8+ with black gasket, but same lumens in the L21B as well though.
Older C8+ SFT40 6500K, 8A 17mm buck driver: 2160 start
Recent C8+ SFT40 6500K, 8A 17mm buck driver: 1760 start.
It’s my recent Alibaba orders, so it’s both L21B and C8+ with SFT40. I test each batch for my store.
México, Simon just out by curiosity is there a way to make the s2+'s metal button with a transparent letter C in the middle or the button completely transparent(just the button the ring with threads can still be metal), this is to see better the lighted switch.
Simon, can you add the T2 lights to your store?
It would be great if you can also upload links to Vapcell 18350 M11 and H16 on AliExpress.
I once had this idea, but I didn’t carry it out.
AliExpress will block battery links directly for some countries.Like the United States.
Ok, i will send you the link later
New coming
SFT-25R
22mm 3V 10A buck driver
15 Thanks
Hi @Simon_Mao to clarify is this a 60degree TIR?
Wow, those look exciting! I was just wondering, is the 10 amp driver made for the LMP w7070st1? If that is the case, when can we first expect to see a flashlight with that LED?
That 10A 3V buck driver looks perfect for SFT40 21700 lights.
Do you think you can update the SFT40 versions of the M21B, L21B, and future 22mm M21A to use it? (instead of 3V 8A)
Does this driver uses LM3409 buck ic ?
I just did that - bought this 10A driver to upgrade an SFT40 in an S21B
Would this be suitable for S21D? Or create too much heat?
