【convoy】
Same here, i can accept those flaws for 40 dollars.
I have a M21J(same TIR as M21K) with a ChangDa SFQ75 and I think it’s got a nice beam.
Maybe the smaller LES helps with that.
I think the ringy beam is with the LHP73B, I’m guessing the SFT-90 would produce a nicer beam.
It’s better on my sft90 version.
A safety feature and yet, the M21B LHP73B has no such momentary mode despite being an even smaller light :thinking:
I agree. I have played with mine a bit more. I have the 5000K and overall I like it. It is not as bright as some of my lights and doesn’t throw as far, but is has a useable beam (as flawed as it is) and was pretty inexpensive.
I typically avoid using “turbo” on my lights. With that and knowing the heat issues, I find the momentary turbo to be a reasonabl compromise.
M21B is a different driver with a different UI. M21K is a e-switch driver and UI.
That’s not the point, it is a smaller light being driven harder.
Very good & interesting point. Same max power 3v 20a from driver, is that correct? Then why doesn’t M21B need momentary Turbo like M21K?
I think I may have the answer (assuming I did not make a mistake). My M21K has a “strange” algorithm for heat management. At level 4 (Turbo-1), the runtime graph shows that it steps down once from 100% to 60%, and that’s it, no further step-down even though T is very hot at 58 C.
This reminds me very much of the infamous S21D with its heat problem. Just one step down and that’s it.
This thing is just stupid :rofl:
11 Thanks
So you’re telling me the M21K had to give up a full 20A turbo, and it still is overheating at 10A? Brother… this is no good. This is why we can’t settle for “good enough” no matter the price point, that is an entirely counter productive mindset that leads to issues like these never getting fixed. I’m going to have to agree with the previous user who said Convoy should focus on driver refinement before new products.
Flashlight manufacturers just cant make it right for everyone.
The light heats up to 58°C - OK.
If the stepdown would be down to 45° or 50°, someone would nag about the stepdown to be too much.
@Toaster79
I also have the L21A and it’s 26650 predecessor. Old one with the 1mm² Osram, new one with the LHP73B.
The difference is funny to see and it’s so impressive to see the raw power of the LHP
6 Thanks
  1. This :+1:.
  2. And this.
What I find, so far & IMHO, is the equivalence of increasing Anduril Tmax to 55-60C. Exactly what I do to my SBT90.2 lights.
Also, the over-heat occurs during testing with light’s head inside a shoebox. I have had no problem with actual use; my use case, YMMV.
I like the driver to stay as is for the same exact reason underlined in 2. “Strange” algorithm doesn’t mean I don’t like it. I had to point it out as part of the “review.”
I actually got yesterday M21B LHP73B and it’s some small monster. On 100% it step-down lower than 35% itself because the later you can’t hold it at head in winter time now (-5C°) I agree that getting hot is better than cold AF eg Wurkkos TS28 or every big manufacturer out there with timed step-downs and no thermal management like Zebralight…
It’s not even about preference it’s literally avout not wanting your hand to explode because the battery overheated. Am I the only one seeing the potential for failure here? Are we reading the same information? The light is NOT stepping down!
Show me a single cell flashlight that sustains 3000 lumens. Show me one that sustains 2000lm like M21K. Those are the highest numbers on the market.
  1. The M21B with LHP73B 20A/3V has a BURN HAZARD warning on it… People say it gets hot (and really hot at that) almost immediately on turbo
  2. It has a a mechanical switch, so probably really hard to make momentary turbo plus it would be hard to hold down the tail button comfortably even if possible
I, myself, am not 100% sure if I’d prefer to have the momentary turbo on 2H or straight max turbo on 2C, both have their pros and cons. But I’m aware it’s a PREFERENCE not an actual, objective issue with the light
LHP73B max mode 10A and Turbo 20A…
Well and how is it feels ? Double brightness and double range? No? But yes, it eats battery at double speed . Ha ha ha.
With that logic we should only use flashlights with less than 0.1lumen to have the maximum efficiency.
Imagine the runtime on a 6ah 21700… And no problems with heat, ever.
Self discharge would be higher than drive current, I think…
That’s one of these funny things.
Super low drive currents aren’t very efficient at all.
You run into high driver parasitic losses and insufficient light conversion, which drops your quantum conversion efficiency quite a bit.
