No we are not reading the same information. Allow me to clarify my findings, so far:
The light is stepping down, 1 step, at least. I stopped testing because that happened with the head of the light in the shoe box for runtime testing, not “normal” condition.
It doesn’t give up “a full 20A Turbo.” It does require click and hold for it, if that’s what you meant.
Not exactly correct. It is over-heating during testing with light in shoe box. In at least my use case, it did not over-heat.
You’re not “wrong” with your opinion, but as have already been pointed out, other owners like this driver exactly the way it is.
The perfect solution here is for all flashlights manufacturers to use Anduril 2 or what Vinh at sky lumen, uses Vn54, something that has adjustable temperature and not times step down, but based on temperature, not time step down
and that way everybody can adjust their temperature how they want.
For those of you people who like 70 Celsius and burn your skin off, increase it to 70 Celsius, but I don’t like my like getting over 45, it pisses me off.
That’s one of the reasons I’m waiting for the Nichia version of the new Wurrkos ts26, cause I can adjust the temperature.
In a perfect world yes, 100%, where every consumer is an enthusiast. However, adapting mass produced drivers to Anduril isn’t so straightforward when you have 90% of consumers who do not want to bother with an ultra-complicated UI. I’ve had people somehow manage to enable momentary Moon mode on my Anduril lights after a few seconds of unsupervision. If manufacturers could figure out a a driver UI with adjustable TMax and other parameters without resorting to Anduril, cool, but probably not going to happen.
I wonder how hard it is to implement Anduril in just Simple Mode, which eliminates the risk of accidentally entering an alternative universe by clicking randomly. I think many people would want from Anduril not necessarily the full set of fancy features, just common-sense UI decisions like
Good roughly-logarithmic ramping speed
No memorization of turbo
Decent moonlight
all of which are missing in my S21E driver with Convoy’s own UI. The memorization of turbo is IMO the most egregious offense out of the three, and a dealbreaker for me.
Really, I don’t understand the decision (for any manufacturer) to design an UI from scratch when the community has already expressed what essential features it wants, in the form of Anduril Simple Mode.
Agreed on frustration of manufacturers trying to reinvent the wheel, I’d not be mad with more lights using Narsil or (?) TomE’s ramping UI. The original Emisar D4 used a simple ramp UI.
I agree. The M21K solves this well enough I think by switching turbo to momentary, but it wouldn’t make much sense on a lower powered light. The SLOW cycling through all four modes is a bit tiresome.
Also, there’s the oft-mentioned ability to go directly from moonlight to low. This is a glaring omission, albeit not as egregious as the first. And on a related note: lower moonlight! Most side-switch Convoys (M21K being the exception) have almost no discernable difference between moonlight and low.
If turbo is momentary-only, it is practically given up. It doesn’t matter if the light if overheating in a shoebox or a fridge, because the fact it’s even getting that hot proves it has no mechanism for temperature regulation, which means it WILL overheat if allowed to. If a million users like a potential bomb that doesn’t stop it from being a potential bomb.
