【convoy】
I’m left wondering if it isn’t better just to have it sustain 2000 lumens… cool runtime measurements
I don’t quite understand those graphs. I don’t understand what you’re saying.
Can the light maintain the 10 amp mode, I think that’s the highest ramp mode, not the turbo mode, without burning my hand, especially after 20 minutes of constant runtime
Can it maintain the 10 amp mode for at least 40 minutes (till the battery voltage becomes too low) without the body handle of the light getting too scolding hot for my hand?
When cooled and even with a 20Wh cell, it is physically impossible for the M21K to have 40m of runtime at full power 10A.
8 Thanks
You yourself said there is no further stepdown from 60%, that is not an appropriate response to heat. Outdoor actual use is meaningless because it is subjective. Right now it is winter in the northern hemisphere. When it’s summer, the light will get hotter.
That’s why I will swap M21K and M26D drivers, I need a hand heater
I would be very cautious with that, some of these lights are treading a very thin boundary with battery saftey and all it takes is one person to lose their fingers before masses of people stop buying from Simon, I don’t someone to lose their hand and I don’t want Convoy lights to be seen as hand grenades for years after.
To be fair, I would think that most people buying Simon’s lights would know what we’re getting into…proper handling, common sense…
But it can be fixed relatively easily if Ace beam and zebra light can do it everybody can do it
You’re right, not 60% per se, more like 2000 lm. I meant “correct” with respect to step-down and response, meaning it’s not timed base (I will clarify the post).
Algorithm if my testing is correct, is very similar to Convoy S21D. Which tested even hotter.
This is not a light for everyone. Only for veteran enthusiasts who are searching for the highest sustained output, and have the common sense of turning it down when his hand feels hot :slightly_smiling_face:.
What battery safety? The M21K has proper thermal regulation and unless you shove a 10A cell inside of this cell, you shouldn’t have any issues.
There’s a reason the worst cell Convoy even sells with the M21K is the Samsung 50S.
Mm yes a $150 convoy m21k, PERFECT for the enthusiast DIY market…I’m being sarcastic and facetious, but do you really want that?
I wouldn’t say no to such a light if Simon put all of his knowledge, experience and strenghts into designing the ultimate light.
Fair enough, we have a market for that then
The “King Simon” line
This issue has existed for the longest time (especially after the introduction of buck drivers), but never seems to attract enough attention toward a solution. My S21E (boost driver) outputs 0.5% for the claimed 0.1% mode, which is not meaningfully different from the 1% mode. And the 0.1% mode on the 8A 17mm buck driver is only around 3x dimmer than 1% and on the order of 10+ lumens, which is quite unusable as a moonlight.
Part of the issue is the absence of a good moonlight, but another part of the issue, which bothers me more, is that the driver simply does not live up to its claimed specs. If it claims to have a 0.1% mode, I expect a 0.1% mode, not 5x that.
Yup , we are all going to blow our hands off for sure.
We base our existence on probabilities. Is it safe to cross the street, even though sometimes people get run over? Well people decide to cross streets regularly.
When I was in aerospace in systems safety we rated danger using probabilities and severity to determine what should be done for remediation. In some cases we would force a redesign. Sometimes it warranted a caution and warning label.
Sometimes, when probability was low enough, we decided to document, but otherwise, ignore the situation.
This last category is where I place this concern.
I appreciate your concern for all of us, but I judge the probability of a catastrophic failure to be so low that it doesn’t even play into my decision about whether I should use the M21K on turbo.
IOW, from my perspective, what was said is an over reaction.
I’m new here, forgive but are you saying the Samsung s50 is not reliable or that the 50s is the lowest performing battery Simon offers with the m21k? I thought it was a pretty good mid to high drain battery or am i wrong. Just curious.
The latter
True. But the contenders are just too strong.
They’re not, just look at the reviews on the webstore
A lot of Convoy lights are recommended to people on reddit and facebook and many non-enthusiast people end up buying and using these lights.
By the way I tried this combo (M26D tube on the M21K) and yes it does work, but I think the smaller spring on the M26D tube is a limiting factor. The M21K dims when going from high to turbo when used with a decent high-drain 26650.
Also, the M21K tube does NOT thread into my M26D. So, it’s not worth the hassle in the least.
Another interesting note is that my M21K from the second batch had a glossy black finish that matched my M26D. It also had a (superior looking) black button instead of the gray button pictured.
If the outside of the flashlight is reaching 60 C, the battery on the inside is even hotter, it does not have proper thermal regulation.
