【convoy】
I sent a message to Simon, asking about the 3V 20A driver for the other M21-series lights, and was told the following
The driver circuit has already been produced, and I am currently producing a suitable spring for the flashlight. The original spring cannot withstand 20 amps of current.
Honestly, I just want the updated UI to work with some of the other emitters. I don’t care about high output, but do want better moonlight and to not have to deal with memory on turbo.
That review is just unhinged, lol.
I give Convoys out to plebs. No issues so far. But I do make sure they’re models with USB-C charging.
Saw that banner on the website. That’s exciting news and worth holding out on my next purchase for. Eyeing a new M21H.
The Samsung 50S is the lowest specced battery that can safely be used on turbo on this light.
It’s the minimum specification. I recommend the 50PL or 50XG instead as they’re better in every single way.
However, I would still avoid purchasing the Samsung 50S considering the other options that are available, as its cycle life is hot trash if you charge to 100%.
What I want from Convoy as a last hurrah for boost lights is a final updated 6V5A driver with all of the latest goodies, that’s it.
That looks like a shill review. Yours, perhaps? :ogre:
Still gave the product 5 stars for whatever reason…
All joking aside, those kinds of people hold scalding coffee in their laps and iron with the shirt on.
If you looked at some pictures of what fireworks do to hands, you would understand why I won’t stop pushing for better thermal regulation…
Excellent news!
I don’t care about crazy high output either because I think it’s not very practical.
I’ll most likely use 10A 40%, or perhaps 10A 100% as turbo (a little.)
I’ll check out 20A 100%, but I’ll probably almost never use it. :slightly_smiling_face:
I will get the pl50 next time, thanks for the clarification.
This is not true. The external heat generated here is from the LED, NOT catastrophic or normal heat from internal reaction of the battery. In normal battery operation like this case, the battery measures 53 degree C after 20 minutes, 5-6 degrees lower than the head external temp.
As already mentioned on this thread, you are over-reacting. Please calm down :slightly_smiling_face:.
It’s been clearly stated the light is not for everyone, same as many high power lights such as Nightwatchs. The hilarious grenade warning could happen with any li-ion operated device, if you want to be completely hysterical.
I mean, it’s true.
A battery discharged at 20A inside of a flashlight will be hotter than one outside of a flashlight.
I am not overreacting, I am actually using basic foresight that maybe we shouldn’t be running batteries past the edge of their thermal limits in order to prevent a catastrophe. I have already shown that these lights end up in the hands of the inexperienced one way or another, and to say that it is hysterical to call for some improved saftey measures in just plain myopic.
There was already a user on here that reported his batteries swelled after using them for runtime tests, @PiercingTheDarkness I believe, which proves that the thermal regulation needs at the minimum SOME improvement inorder to avoid worse.
Light does not stay at Turbo long. Stepdown to 2000 lm is about 4a if I read Koef’s curve correctly (?). That 53°C came from actual measurement of the battery.
“We” are not. Did you see what I just posted? Battery T=53°C. Also, this 6000 lm light is a “baby”, not nearly as “dangerous” as several high power lights on the market such as those 20000 lm Nightwatchs and Haikelite, etc. That’s the reason people feel you are over-reacting.
Warning about li-ion catastrophy is valid and always appreciated, agreed. OTOH, it’s a problem common to all li-ion devices and there is a balance between one post and continued indignation/OT noise. Especially as I have painstakingly tested & documented my findings. Let’s move on.
If I remember correctly, it was an issue with a specific model of “Molicel” battery and not related to “Convoy”
Man, all this talk about thermal runoff and high power, and all I want is an updated AAA twisty or that AA headlamp he mentioned last year. Then again, I know I’m also in the minority.
I agree But as is said, “a word to the wise” should be sufficient, without a crusade to save us from ourselves.
Are we in the Nightwatch thread or the Convoy thread?
It’s always the first to raise the alarm that are shunned but ultimately vindicated
This statment Is total bull!@#$. Just last night I was testing my L21A with LHP73B @20A. Left it tailstanding in my living room on full power. After temp protection kicking in the housing had about 50°C. Hot but bearable to hold. So turned it up again to full power for a few minutes and when the body got hot enough for me not being comfortable anymore I pulled out the battery and it was way lower temperature that the body itself, maybe 35°C. The battery tube got as hot as the head.
You see, the battery itself doesn’t touch the body anywhere and it has plastic insulating layer wrapped around it. Also there is air between the tube and the plastic wrap. So only way of getting the heat to the battery is through those springs. And that’s not gonna cut it now, is it.
8 Thanks
