【convoy】
Just realized the AI used a 2mm wall thickness.
The equivalent would be:
R = 11 mm, r = 9 mm:
A = π × (11² − 9²) = π × (11 − 9) × (11 + 9) = π × 2 × 20 = 40π ≈ 125.66 mm²
or 1.2566 × 10⁻⁴ m²
Oh, right, my bad
If I order a C8+ and L21B with a CULPM1, anyone know if these combinations have the focus issues currently? Also curious about the SFT-25R with the same two lights.
I’ve seen a lot of talk about centering rings, gaskets, and reflectors causing issues and got overwhelmed.
yes, these ones have had some bad reflector batches and gasket issures, generally we stay SFT40 and bigger, but im not sure about most recently. for the L21, i believe the 11m reflector hole is fine, but gaskets may be off still, so i dont know for sure. the C8+ i think is just gaskets maybe, maybe, i am not sure about any of these. SFT25R/W5050SQ_ might be ok in the C8+. for both of these i would go SFT42R cuz it should be able to escape the focus issues and throws almost as much as the 25R.
I recently purched an L21B with 42r and an C8+ with CULPM1. First pic is L21B second is C8+.
Unfortunately the above beamshots are at too close a distance to reveal focusing and centering issues. I’ve got some horribly deformed beams that look completely ok at this distance.
With the C8+, picking the 9mm hole reflector should be fine; the 7mm reflector has a deformed surface that cannot properly focus anything smaller than a SFT40. For L21B, the 11mm hole reflector should be ok. Interestingly, it’s always the smaller opening reflectors having issues–somehow having that flat annulus at the bottom seems to introduce manufacturing difficulties.
Adjusting the gasket is a much easier problem than a bad reflector; use sandpaper or tape to lower or pad it.
With the S6 SFT-40, even though there is no 5mm 5050 gasket, somehow I am getting more throw with the 5mm OP reflector than the 7mm OP reflector.
Throw: 5mm OP + 7mm 5050 gasket (Butterfly shape) > 7mm OP + 7mm 5050 gasket (Butterfly shape) ≈ 7mm OP + 7mm 5050 gasket (round shape) > 5mm OP + 7mm 5050 gasket (round shape)
Simon shipped 5mm SMO + 7mm 5050 gasket (Butterfly shape) by default with S6 SFT-40 but the hotspot is slightly uneven, I am happy with the 5mm OP.
The S6 reflectors is a different situation because it doesn’t have the flat annulus at the LED hole; it’s just a parabola with a wider opening. Because of this, you get a tiny bit more optically functional area (i.e., less truncation) going from 7mm to 5mm, so you get more throw.
So how do I know which LEDs get a 9mm reflector for C8+ and which ones get 11mm for L21?
I would put a note in the order and ask for it explicitly, or buy a spare reflector.
will the 9mm throw any better cuz of this, in c8+ sft40? or it still focuses good enough. and how easy is a mcpcb emitter/driver swap for c8+? i might want to 42r it.
I was thinking of getting a light for my bike using a striped TIR for a wide beam. Is there a good option for this? Has anyone requested a pre-installed TIR, or is there a light where installing a TIR is especially easy?
S21E is really simple to swap and there are multiple lenses available.
Ans you can buy it with the lens already installed
With SFT40 it matters less due to the large LES, but 9mm will still give you a better, cleaner beam. If you are ok with basic soldering and have thermal paste, emitter+driver swapping a C8 is very easy.
Just switched out the LHP531 in my T8 to an W5050SQ5 - damn, what a nice hotspot, super clean.
Also the new SS bezel looks so nice.
But because of the height of the new LED, I can’t screw it down completely or I destrox the gasket. I will probably 3d print a distance ring to put between case and bezel, just to close the gap.
Post some beamshots, please!
The main issue is that I’d really want to avoid Anduril on a bike light. The main issue is that it is very complex to get back to the bike flash once you go past it, and that is not something I want to deal with in a bike light. (Heresy I know)
I was hoping to use the 12 groups driver.
In which case it is even harder to get into the bike flash mode. Yes?
S21A/B then. S21B is easier to swap the lens as you only need to unscrew the bezel contrary to S21A where you need to remove the pill. You also have a way better choice of drivers with S21B as it hosts 22mm driver.
