Thanks FmC, that build thread really straighten out a lot of questions on how to make a good optimized Courui D01 mod.
Please do a similar follow up thread with the 86mm reflector Courui D01 mod
I spent a few hours today working with the camera adapters, & came up with a combination that doesn't require using the original bezel at all, & gives a few extra mm height.
@ Linus; do you mind if I put up a separate thread for my mod?
I know it is none of my business, but why not to keep all the information in one thread? Or at least post here a link to your mod. Can’t wait to see your mod too! BTW is there a way to use a normal lens? Those filters you use are rather flimsy and too thin. I like robust stuff that can take some punishment. I don’t like the risk of breaking the lens and messing up the reflector due to a puny lens.
To me I find it difficult to find particular points of interest when a thread gets to big. With its own thread you have better results with the search function, though I am a bit simple at times.
I'll do a separate thread. This is, after all, Linus' mod thread.
Obviously, I'll link to this thread, & give Linus the credit for coming up with the idea.
:beer:
Thanks FmC for doing a write up (i hope ;)) like you did on your first Courui D01 mod thread :).
I i learned a lot of things i will be implementing, if i try a optimized Courui D01 build & i suspect i will learn just as much from the follow up, Courui D01 mod with the 86mm kaidomain reflector thread.
Hey guys,
At the bottom of the OP of this thread, yo will find a full list and continually updated of ALL the mods contributed by our fellow BLF members, including this new thread.
Hope this helps!
It does, i will be referencing that list, when try my hands on some of this Courui D01 fun you guys are having
any links for this ?
This is the one I used.
Keep in mind it's not a plug & play solution; you need to remove a fair bit of material from the inside lip of this part.
thanks but i dont have tools to remove material is any other option to be plug and play ?
Not that I know of.
LinusHofmann will tell us :),in his setup removed about 0.5mm from the reflector.
0.5mm doesn't sound much, until you realize that it is around the entire circumference, & if you don't get it even, the reflector won't sit in the center, therefore the LED will be off-center.
You also have to take some material off the inside of that hood at the step where the smaller thread is, otherwise the reflector will not sit down enough.
i thought i will be able to do it (0.5mm) with sandpaper.
i also need to find a centering ring .
another question ,how do you screw 77mm Fotga wide angle lens hood to the body of the flashlight ? the threats in both sides are male.
if i install the stock lens ring the KD reflector dont fit , or i’ll have to cut the stock lense ring.are they any camera parts that they will do the trick?
btw i bought the 82mm hood $2.64 from http://www.ebay.com/itm/320831050836?\_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
