I’m just getting underway on my Courui mod. I’ve installed an omten lockout switch and braided the springs, now I’m just waiting on emitter, driver and mcpcb.
I’d be happy to swap my stock driver for your damaged one since I’ll just be using it for a contact board.
Looks like my FETs are marked "A0DG". I ordered some of the ones linked above (just in case as itinifni has graciously offered his to me). I couldn't find much searching Google for "A0DG".
So Itinifni and I swapped driver boards. I immediately stacked 2 R100's on top of the stock R200. I've got 22ga silicone wiring to a dedomed XM-L2 U3 1A on copper. Tail cap copper modded as well as springs. Tough to get a current measurement as I have to do it "SRK style" (so tail cap doesn't even come into play). On 2 fully charged LG 4.35v cells (too tough to hold 3 cells together) I'm only getting 3.05A on high. I was expecting much higher. No bonus moonlight mode though.
Does this driver just not want to push high amps through? I was hoping for more like 6 amps. Inside the beam just looks meh. Gotta wait til dark to try it outside.
When I bridged the resistor completely, I only measured a little above 4.5a, using a 25r.
That was with an XP-G2, that I bought quite a while ago.
I notice you are using an XM-L2 U3. If it’s like any of the recent one’s people are getting, that’s most likely why you are getting such a low reading.
Do you have an old XM-L to try for comparison’s sake?
I do have an old XM-L but would hate to do the swap. Do these XM-L2 U3's have really high vF? Like 4.2v at 4A or something?
Tried the beam out my backdoor now that it's dark. It's pretty impressive, more so than I expected. Can't get to a better test location right now due to all the snow.
I wonder if I should try bridging the sense resistor?
I have both of these LEDs ready to dedome and put in the Courui with a fet driver and copper heatsink, which one would you choose? I want best balance of CW tint, throw and output.
TBH, I don’t think you’ll end up with a true cool white with either, after the de-dome.
I know it may vary somewhat, but from the few I’ve done, I’ll bet the XM will be cooler, but might lean to the green side, & the XP will will be a little warmer, & tend to the yellow side.
If I where you i would chose the XP-L V6 1A dedome.
I did that in a DD Zeusray a while ago, the new XM-L2 U3 are almost impossible to get much over 5 amp, the XP-L can go to around 7A in a DD or MOSFET driven light with a strong high discharge battery + fully low resistance mods.
The amp estimated is for led’s with the dome on, i think you lose some of the top amp & lumens with a dedome, but the XP-L are said to lose less.
I liked the XP-L V6 1A’s tint after the dedome, more than the CW xm-l2 i have done before, non of that sickly green hue :Sp , but a yellowish NW but still CW tint, especially at distance it look more CW than close up.
I think that’s the one Dale has used with good results.
I have several camera filter lenses on their way to me on the ‘slow boat’ to test in a few throwers, & will post before & after results when I get the chance.
@will34, please try to measure somehow the difference in throw between the XM-L2 U3 1A & XP-L V6 1A.
Any detail would be very interesting, as far as i know from here no one have tested & reported on that yet.
My guess is that the XP-L should throw better because it can be driven harder & with more amp & and therefore should throw longer.
I have just been debating this in the Zeusray thread check out near the end, it hope you can add some insight in to any possible differences between the two options.
Ok I took my first lux reading ever last night and calculated throw at 118kcd. This is with my dedomed XM-L2 U3 1A driven by (3) fully charged LG 4.35v cells with stock driver resistor modded for near direct drive performance (I measured 3.05A input current). My emitter is up into the reflector as far as it will go and focus looks best at that point. My meter is the HS1010 cheapie. I was measuring "472" on the "x10" range at 5 meters. Seems a bit low to me, but the light is really performing well! What are others seeing with dedomed XM-L2's?
I agree it seems a bit low. Two things I would do before messing with the focus, confirm the batteries in your meter are fully charged and take you measurements from a longer distance. I measure my throwers at 9 meters, if I had more room I’d go out a bit farther.
For reference my stock D01 measured 77.3kCd stock and 82.9kCd after resistance mods, both converted from 9 meters using an HS1010A. That was with the driver you’re using now in stock trim and the dome on.
The batteries were the "heavy duty" ones that came with the meter and were never used until last night, but I'll try some fresh alkalines. I did this in my basement, so I'm limited how far I can go. I might be able to backup to 7 meters.
I picked up one LG high drain cell. I'll have to charge it up though. I don't see why I need a high drain cell though. Even 2 reg cells should push 5 to 6 amps - especially 4.35v cells. Maybe it's an issue remaining from when I shorted the reflector across the emitter wires.
Nightbird95 measured 3.62 Amps reading at the tail cap with batteries @ 4.13 volts, with the same mods as I, although he didn't say what battery he was using.
I know I measured just over 4.5A from my setup with a fully charged 25R, with resistor bridged; The same cell, thrown into my A60 w/Nanjg-105 fet modded driver pulls ~5.5amps.
Even though it's a FET based driver, I wouldn't be expecting big output like we are getting from the BLF-DD type FET drivers. 5-6 amps isn't going to happen with the stock Courui driver.
I managed to have a few minutes last night to take another lux reading, this time at 20 feet (6.096 meters). I measured 3340 lux which calculates to 124kcd. I was slowly moving the light around to check for the highest reading and it was really "touchy" as if the highest reading is only from the exact center of the beam. A millimeter of movement and the reading dropped significantly. (I suppose this is normal, especially with a dedomed emitter.) I did not try other batteries in the meter; If I get chance I will and also try measuring at 24 feet (longest I can do in my basement).
Charging up my high drain cell now for current measurement tonight.
