Balance is great in the hand, maybe a very very slightly tail heavy (surprisingly) when held in the middle of the grip like this…
…but feels spot on when the whole hand is on the grip and most of the support is from the middle, ring and pinky fingers. More as a result of luck than planning though
How did the cupcakes turn out as Wavien Collar alternative? Did you try them?
I am trying a similar thing, in my case I ordered these
They are called plain cap beads and are used in jewelry, probably made out of plastic and plated with or dipped in silver or other shiny material. Note that they are much smaller (around 10cm instead of 40cm) so you could use them in smaller flashlights. I will post results once I get them and test them. You could get other ones here:
They also look spherical and shiny and the hole seems more centered but a little more expensive than the ones on ebay.
I stripped the anodizing/coating back on the cupcake trays to expose the bare aluminium. But I didn’t have the right polishing compound so I’m waiting on that to arrive before I can properly polish it up. Key to the efficiency of this light recycling will come down to the quality of the reflective surface and good spherical geometry.
Are those beads properly reflective on the inside? They look a bit matte to me, similar to what I saw with the Christmas balls.
Very shiny on the outside (which is the side that’s visible in normal use right?) and not so great on the inside maybe?
If you can polish the coating without removing it, it looks like it could work very nicely.
I will let you know how they are once I receive them. So did you use sand paper to strip the coating? And what compound are you going to use for polishing them?
Yeah, sandpaper to strip the coating. I think it could be anodizing. it’s quite hard to remove. If it is ano, applying some degreaser to weaken it might be a good idea.
I ordered some polishing compound off ebay, the standard blue bar of aluminium finishing compound and a tub of Mother’s Mag and aluminium polish. That has some good reports from other BLF members so hopefully I can get a nice mirror finish on this surface.
Toothpaste for polish? That sounds interesting, I’ll give it a go. Thanks
I saw that they offer solid brass bead caps. Maybe there’s a chance of finding some solid aluminium ones somewhere? Would be interesting
I also found these as possible candidates:
They are hemispherical cup for washers. A good buffing and polishing could make them shiny and more reflective.
and if u search Google there is a place that sells Stainless steel disc or sheet and i was going to drill a center hole and use the block to make my shape ?????
went with stainless steel because its shiny to reflect the light better ?
Loving all these ideas, might be worth starting up another diy collar thread soon.
I’m not sure if stainless would actually result in a more efficient reflective surface. Mirror polished aluminium is pretty good but I don’t know much about this stuff in terms of actual values. I believe the usual reflectors use a layer of vacuum deposited aluminium to achieve the final coating.
Different reflector coating materials. are shown here, vacuum deposted aluminium is rated at about 90% reflectance. No idea how close you can get to that by simply polishing the bare metal though.
Even more interesting, those look like they come in a male and female set. Wouldn’t that be perfect to press and form sheet aluminium/stainless or whatever into little spherical cups?
They even come threaded so making a little squeezer with a threaded bar and set of bolts seems rather easy?
The material that the dies are made of wouldn’t matter then .
I think I am going to order a couple today. I was thinking of sanding and polishing them to a mirror finish and using them directly but perhaps I can use a very thin aluminum or copper washer, heat it up and shape them as you suggested. Keep in mind that these are not an entire hemisphere, only part of a hemisphere so one would be missing the light that could have been reflected from the sides.
Well, if the hemisphere is incomplete, one would be missing almost all of the light, because it would be out of focus, not directed back to the die. One would have to figure out at what height to float the thing over the emitter (not to mention HOW to do it) in order to get the light focused back to the right point. Probably better to use it for a mold to press a thin sheet of metal into the right shape, if that is possible.
