COURUI switch replacement
can anyone help me find a replacement side switch for the courui, i was in the process of doin some bods when i realized that i had somehow detached the pad from the back of the pcb of the switch for the +ve connection. its such a small pad and there is no way of fixing it so im up for a new switch so if anyone know of a replacement could you let me know. ohh and i dont want to just rely on a tail cap mod as i like having the side switch there.
You could drill a small hole through the PCB, poke the wire through, & solder directly to the switch leg.
Im not 100% sure if it goes directly to the switch leg. It may be a via i think. Ill have to have a better look but it may be my only option ay the moment. I guess i could de soilder the switch from the pcb and backtrace the connections and soilder directly to the switch. Id prefer a replacement switch but beggers cant be choosers i guess…
Everything can be repaired.
Which dimension has the switchboard? Check the oshpark thread, there is a switchboard for eswitches…
Can you post some macro photos so we can see.
so ive had a look, i may be able to use the other set of contacts on the board as the switch has 4 legs that may be connected to the other pads, here are the pics for reference.
