By the way, an 18350 cell is bigger than a CR123/CR123A cell.
There is no subforum just for 18350 flashlights, though, so feel free to ignore me.
Good luck in your search!
CR123 should be pretty much 16340 size, shouldn’t it?
Does it have to be this size, or just “small with decent battery”? If so, could extend the search to 14500, like a Lumintop EDC15 or similar. Afaik you can get both 16340 and 14500 in roughly the same capacity.
There is a bunch of nice 16340 lights I know of, but I can not remember a single twisty
It is. I’m getting confused. My brain is going back to AW RCR123 days, long before we were using 18350 with built in charge ports.
Knowing this guy he just wants super simple, either on board charging or a cell with a port. Size must be pocket and have a keychain/lanyard loop. He lives a self sufficient lifestyle, has hens etc, so needs reliability, ease of use, and definitely no magnets as he’ll have a knife, maybe some nails or staples in his pocket.
He’s an actual daily user, so his needs are pretty easy for him to define. Anything 14500 up I reckon.
Oh no! I’d completely forgotten Dark Sucks took on a few of the 4Sevens lights. I knew this thread may be perilous for my wallet, that MKIII Turbo is fantastic.
Way over budget for Hugh I suspect, he really isn’t going to understand just what he has, and he’d never justify the cost.
That’s really kind mate, thank you. As a creature of habit it might well be the ideal solution, I’ll ask him. Obviously all shipping costs would be covered by myself, and also happy to offer you a token of gratitude in some way maybe?
Honestly, it’s fine. It works but it has been pocket-carried and looks a bit worn. If someone can make use of it I’d rather that than it just sit in a drawer.
Original E15 (cr123a-only tubelight) or was it the second gen (cr123a/16340 with flared out head)?
I had a first gen E15 as my keychain light for a while, eventually went to a Foursevens Mini MkIII because the keyring hole got too thin on the E15. It’s a little bigger and not cheap, but the UI is customizable and it has a decent emitter.
Another option could be a Jetbeam Jet-II MK, though the mode spacing is not that good and the stock emitter is low-CRI CW (just like the E15). Pretty cheap on aliexpress, can be found for less than $30 if you look around
When I wanted to replace my E15 I almost got the Jetbeam, but the Mini MkIII had better modes.
