CR123 to 18650: How To
I recently purchased a DRY which I love except for one thing: it's inability to accept cr123a batteries. So I decided to do something about that, and than this project was born. :)
Start with some 3/8 inch aluminum rod purchased at the hardware store. I got 8 feet for 10 dollars so one piece will make many.
Cut it to length. 67 mm is the length of a protected 18650 and 34 mm is the length of a cr123a so 67-34=33. So the spacer must be 33 millimeters long.
Take some 3/4 inch heatshrink tubing and slide it over the aluminum rod.
Use a blow dryer to heat it up so it tightens down over the rod.
Then take some electrical tape and wrap it until it is about 17 mm thick. Then take the 3/4 inch heat shrink and slide it over that. Again use a hair dryer to shrink it.
Then put it in with a cr123 and your done. :) All in all this mod took 30 minutes including some experimentation to figure out how to to do it.
Then repeat 2 more times if using in a DRY.
To Be Continued...
Nice-looking project, and a GREAT price on the aluminum.
I would be VERY careful about using anything but IMR 16340s/18350s in the DRY, however.
my hack is a wood dowel with a screw.
X-infinity !!!... furthermore using low $, non-USA made primary CR123 cells in a DRY (high current draw) is very risky.
And you definitely DO NOT (!!!) want to mix 16340 with 18650 as the OP shows in the last picture.
i love this site. at least once week I see a picture that reminds me of how I over complicate everything.
I'd been thinking of some similar ways to do this (though I don't use cr123), but I think you hit the easiest I've seen. I even have a large plano sort box of brass wood screws....
on second though, maybe I'll just use steel instead of wasting the long ones on spacers...
Yes I am aware of the risks of mixing cr123s and 18650s. I just took that picture then since I had not yet finished the rest of them. I am currently planning on using surefire brand cr123a batteries.
I just buy dummy cells from battery junction - I think last time I bought 8 of them for something like $2 each.
That pic did scare me for a moment!
Nope, I would never use them like that I will put in a new picture with three sf123a batteries.
I'll make you two spacers if you want. You know me...
How would this do in a 4Px18650 caddy for back up use with primaries?
