Just discovered this by pure chance at Home Depot in electrical. I was actually looking for the vaunted & apparently can be hard to find 3in1 Professional Silicone Spray (which they didn’t have) and noticed this little can on the bottom shelf……
So for $2.98 I thought what the heck. Boy am I glad I came across it. Let me tell you, this product works wonders and then some for safely cleaning, lubing, & protecting threads and in general all contact surfaces where electrical resistance should be minimized and electrical conductivity needs to be maximized. How do I know? I had some lights that were starting to flicker. So I took them apart and wherever electrical pathways needed to be maximized and protected I swabbed them with a Q-Tip dipped in the 2-26. The black cruddy stuff that came off onto the Q-tip was profound. Plus again it lubed the threads with a very fine film. According to the can, 2-26 “leaves a thin, molecular, non-hardening film”.
Needless to say there are no more flickers whatsoever on all lights treated. And I dare say their output is brighter. One other thing, this stuff doesn’t dry out and leave minute particles everywhere - which in my mind aren’t probably the best thing to have floating around anyway. Correct me if I’m wrong but I believe the 3n1 silicone spray does dry out into tiny particles.
I think you don’t want any kind of dielectric products on conductive threads & contact areas, right? Some silicone lubes can have this dielectric effect. On o-rings no problem to use a silicone-type lube but otherwise I think you really want some of this kinda stuff that’s also importantly safe on plastics. I’m now coming to find out that a lot of electricians use 2-26.
Give it a try and see what you think. I think you’ll be duly impressed. $2.98 for a compact spray can that’ll probably last you decades.
Further proof? The little promo Ti that I received today from Thrunite after about test 10 twist-on-and-offs suddenly would only go into “firefly mode” and not high. I’m thinking great a defecto. Took out the 2-26, sprayed a touch into a Dixie Cup, dipped the Q-tip, and proceeded to swab all threads. The swab came out black. Swabbed it again until it stayed white. Guess what? Fixed the problem immediately. And I do declare the little Ti is now definitely brighter. No doubt about it.
I tell ya, I’m onto something here. $2.98? Forget-a-bout-it. This stuff rocks. 8)
This is for the 11oz can it appears per one of the comments. I think they also carry this size at Home Depot. Don’t need even that much for our type lights unless you were doing production. The 5 oz can believe me is P-L-E-N-T-Y. I should get a sales-rep position with this company. I’d sell tons.
http://www.amazon.com/CRC-Industries-02005-Multipurpose-Lubricant/dp/B0013J41KW
However, I should probably remedy that. :P The reason I say that is because with a good battery the HD2010 will pull 3-5 amps stock and if you reduce the resistance much more. I experienced the same problem with an old XM-L drop in when I replaced the wires with teflon ones and wired the spring. I fried the thing.
