oneil4
(oneil4)
May 8, 2022, 3:11pm
1
hi, i try to create light based 1.5v
for you, my circuit diagram is correct ?
again, actualy try to use QX5252 but off at 0.9v ( because protect battery Nimh or other )
do you have simmilar chip whit down 0.7v or less ( not joule chief, because is hard for me )
finaly, create pcb whit chip on the site jlcpcb ( I need the chip on this site, so I can make everything assembled on this site )
https://jlcpcb.com/parts/componentSearch?isSearch=true&searchTxt=driver%20led
thank you
I can’t comment on the circuit correctness, but I don’t feel it’s required to protect a NiMH from deep discharge— in fact it’s better to discharge completely to make use of the maximum capacity and avoid the memory effect which can still happen, even if less likely than NiCd.
oneil4
(oneil4)
May 8, 2022, 4:19pm
3
Hello,
thank you for the answer
I don’t intend to use a Nimh type battery, but a non rechargeable alkaline battery in LR20 format.
it’s for create a light for my child (I made a post previously).
I wanted to use the joule thief, but it’s complicated for me, so I’ll look into doing it with a led controller like the QX5252,
I don’t know if there are similar drivers on the jlcpcb site.
after add 2 functions pir sensor and night sensor
5252F is wired as such
BAT: TO-94[Pin2] / DIP-8[Pin7] = Inductor + (Optional on/off switch) + Bat Positive
VSS: TO-94[Pin3] / DIP-8[Pin2] = Led Cathode + Bat Negative
LX: TO-94[Pin4] / DIP-8[Pin3] = Inductor + Led Anode
gchart made a joule thief that that runs down to 0.7v with TLV61220 or ZXLD381
A member here approached me about making a low output, long runtime boost driver to fit the Convoy T2 (aka Manta Ray S1, also available as a host at Kaidomain). Target output was ~1 lumen. No mode switching. Currently 17mm but could be made to be 15mm or about any size.
I went through a couple iterations and ended up creating one that ran an XM-L2 at 2.5mA for ~0.7 lumen for 98 hours on a 900 mAh AAA Eneloop Pro. So on a AA battery, it should run for 12+ days. It runs down to ~0.7 V.
Current i…
oneil4
(oneil4)
May 8, 2022, 6:15pm
5
TLV61220 and ZXLD381 don’t have on jlcpcb
too bad, I’ll go with this one,
Does my diagram look right then?
