My usual T50 mods with old XP-G2 S3 2B managed to do average of 810 FC, 5 meters .
This batch of old type of XP-G2 S4 2B emitters has…. 950 peak and 912FC after 30 seconds(as Djozz like to measure)
I am measuring with Uni-T light meter so when you convert those FC numbers it means 218KCD(good S32B) vs 245 kcd(good S42B)
I will also add here that I did not include Djozz +10% more formula here. This are pure Uni-T readings and Djozz said that Uni-T meter under reads XP-G2 S4 2B for more than 10… So I really don’t know… This original measurements seems realistic to me so I will not calculate +10 data here.
Peak numbers would be 255kcd… But as Djozz says no sense in measuring first few seconds although Enderman or any other guys that build supper cooled lights could benefit and maintain those peak numbers.
Ah yes… Current draw is 4.35A measured on uni-t unmistakable clamp meter and very hard press to the battery. Driver is diy Djozz style FET driver(have tested few FET drivers but they all perform same so I really know it is very good fet driver).
Current draw indicates that this probably was not the best pick either. But…
Yes! This is it! The king is in mine pocket. Green monster is back
Yes… 2 - 3 year of work at least. But I kinda limited myself with this one cause even if something new and better rises up I will still be stuck with them.
I really think there is no better emitter in this size, performance and price ratio. This emitter is born for single cell FET lights like no other… 4.3A current draw is nothing and performance(lux, kcd) are wow! You can safely run it on turbo all the time and nothing bad will happen.
Forgot to mention that used battery was samsung INR 30Q.
So theoretically it could pull even more with sony VTC5 or Samsung INR 25R which are reporter here on BLF as the highest current cells.
