Where can i buy a Cree Q5 drop-in for a 3D Cell Maglite thanking you in advance
http://www.malkoffdevices.com/shop/36-dcell-dropin-to-fit-maglite-p-1.html
Or XM-L
http://www.malkoffdevices.com/shop/xml-dropin-module-for-34d-maglite-p-124.html
As you are in the UK you might want to check out The Torch Site. They do an XP-E and an XP-G drop in. Cheap and easy to fit, although not the most power or best heatsinking but they do work quite well and are good VFM.
Any reason you want a Q5 specifically? (presume you mean X-RE Q5?)
Yes a friend has one in Maglite 2 D Cell, and i was very impressed with it has an aspheric lens on it he has had it a good few years now but the place he purchased his from Kaidomain no longer have them thank you for the reply.
That would have been perfect but the shipping cost is more than what the item cost thanks anway
Ok, then go for this one.
http://thetorchsite.co.uk/TerraLUX_TLE-6EXB.html
It will work fairly well but due to no heatsinking will not run at full brightness constantly.
I think this may work if you're wanting an aspheric (DX)
That one is a little bit to small, you would need to wrap a O-ring around it to make it work.
I have that Malkoff XP-G drop-in in our Maglite. It's been a while since I got it.
BTW the Maglite twist focus is still retained. It's nice.
Maybe this one:
http://www.led4more.de/cms/index.php?cat=KAT08&product=P000011
Its from Germany, shipping to other EU-countries is 6€.
