I Just received the above torch from china but can’t figure out how to adjust the light so that it varies the focus. It came with a white plastic tube but can’t seem to fit it properly. I’m probably being a bit thick here but any help is appreciated. It does say on the ad that the torch is adjustable so I hope this is the case.
That white plastic tube is for use with 18650 batteries, since they are a little skinnier than the AAA battery holder. It is only used around the 18650 battery so it fits better inside of flashlight.
I’ve got one and you just pull out the finned front part. It is sticky the first time as it’s an “O” ring that gives the friction unlike some zoomies that have a metal spring ring. I like the flood on it but am thinking about sticking in a better driver as it’s a 5 mode with that next mode memory. Yeuch!
Absolutely! Don’t be afraid to break it - just grab a hold of it and give it a strong tug. Once you get it moving it should ease up a bit. Some are so sloppy loose that you can’t pint them up or down without them zooming in or out. Others are so tight you need two hands and a bit of force to slide in and out.
