Crelant 7G5CS throw experiments.
experiment for today is a XP-E2 running off the stock Crelant driver. dome on. idk if i will de dome or not. i think a xp-g2 driven harder will throw farther. no outside bean shots yet, my camera sucks.
Reflector head, light on lowest setting
Reflector head, highest output
collimator head, lowest output. beam is better focused for real, but there are some artifacts and stuff. possibly because off the white spacer that goes between mcpcb and reflector? may help to be black. will try that shortly.
collimator head highest output. again, camera sucks, does project a image of beam at any brightness.
oh and a XP-E2 will take 3+ amps for about a minute before it starts getting blue. even not on a copper mcpcb. i will be rebuilding this with a Noctigon board. will also be trying a XR-E, although idk how that will handle the power, if at all. XP-G2 will go in it. 2 other LEDs which i cant remember at the moment.
I am really interested to see how this turns out 8)
20K lux on low at 3 feet with the collimator head. lol low as in hit the side switch 2 times low, not the low you get if you press and hold. high at 3 feet instantly maxed my meter out.
it is fairly bright where i live and kinda raining at moment but i can just barely see it at a quarter mile.
went to a darker spot and shined it at a smoke stack that is 2000 feet away and could see it slightly. will have a friend that lives near it go outside next time i test it to verify i am hitting it. this XP-E2 is like a laser beam with the collimator head, and i still think it could be focused better. not much i can do there unless i put a piece of copper underneath the mcpcb. seems like if i unscrew the lens holder in the head and move the lens away, it focuses at short distances better, but if i have it screwed tight closer to the led, it focuses better at 30 feet or so. so i wonder if the led was even closer still how it would focus.
30 foot shot indoors on the lowest output the light will do
better shot of the beam at 6 feet. changed exposure a little bit on my webcam. also lowest output.
Dedomed the XP-E2 and damaged it trying to get all of the dome off of the die. put another XP-E2 in it however this one was a different tint. this one is a unknown tint. actually the first one was a unknown tint as well. this one seems a little cooler with dome off. could be wrong. definite difference in color of die when checked with UV light. XP-E2 from yesterday is almost pink under a uv light. very bright. one from today hardly even glows at all but it is orange-pink
pics to follow when it gets dark
went outside with both heads. reflector head throws damn far with the dedomed XP-E2, almost as far as the collimator head. if it was darker here i could tell better but id say 2000 to 2200 with reflector head visible, and 2300 to 2500 feet or more with collimator, even though it may not be fully focused.
this picture here is the distance from a smoke stack to where i was standing. on first turn on, with light on high until tint starts to change from it being driven at 3a on a aluminum mcpcb, i can EASILY see it light up the smoke stack. same as if i was a few hundred feet away with my 1200 lumen Solarforce. this angle put me above all the street lights and the stack is fairly dark. after a few seconds if i ramp it down till the tint comes back, which is probably 2 to 2.5 amps, it it still just barely visible from here on the stack. reflector head is hard to tell cause of spill but it looks like it might be hitting it.
this picture is the second shot i tried. there is a stop sign right there that i can easily see getting brighter and reflecting with both heads, collimator is brighter. on low, which is .75 to 1 amp i believe, the collimator still hits it. reflector head on low just barely is noticeable but does just barely light the sign up.
really has me wondering what the xp-e will do on a copper mcpcb when those come, and what the xp-g2 and xr-e will do when i get them. this light is a beast for sure. some night this week, i will walk to a darker spot where i have things at 1725, 2783, and 3632 feet. we shall see how that goes. i will repeat all shots for all emitters tested. just wish i had a better camera so i could get pics.
ledengin lz1. handles the amperage better than the xr-e. no blue shift that i have seen yet. die image looks better than the xr-e too. fully focused as far as i can tell. range test tonight. looks much better in person.
lowest output, collimator head.
highest output, exposure adjusted to make pic darker for better image of die.
how it looks on high without adjusting exposure.
hot spot is ugly with reflector head, led needs to sit higher in reflector a little. black hole in middle of the spot
