As I’m sure you all know this is a 4 AA light with an XPL-Hi LED, at a very reasonable price, claiming constant current circuitry, two output modes, max at 1000 lumens, and some hidden joke modes.
Mine is nicely made, not quite flawless, but pretty much on a par with Fenix et al externally at least. The integral battery carrier is nice. The switch design is nice, only two modes (plus hidden joke modes), and each is adjustable by ramping, just hold the switch down, very nice.
I did some measurements yesterday and it got very hot. By 1 hour is was dim, I forgot to measure after 35 minutes. After 35 minuttes it was down to 550 units from 780 at the start. Today I repeated the tests, and the regulation was worse (not sure what has happened, maybe room temperature changes?):
5:10 = 939
5:15 = 745
5:20 = 695
5:25 = 6:50
5:30 = 605
5:35 = 562
5:40 = 623
5:45 = 487
5:50 = 43*
5:55 = 400
6:00 = 366
6:05 = 330
6:10 = 300
6:15 = 268
I then got bored ….
The units are arbitrary since I cannot accurately measure output, only brightness in lux.
So it looks as if the previous run on high has burnt something out in the circuitry or the LED. My feelings are that this light is best avoided. It has poor regulation. I noticed from other reviews that Crelant lights seem to have poor regulation. What a shame. It seems also to be inefficient compared to my other lights, but then again it could be that running on very high (near 1000 lumens apparently) at the start takes its toll, since an LED drains battereries disproportionately when run at very high outputs.
As for mine, the poor regulation means it will be relegated to sitting in the car as an emergency light. Even then I’m not convinced the circuit efficiency is good, so perhaps it should not go in the car, where I might need light for a long while e.g. if walking at night after a breakdown.
