Is there a crowdfunding campaign for these?
no =(
For those starlike spectrums, what device is measuring up to 1100nm+?
UPRTek PG200N 350-800nm
LisunGroup LMS-6000S 350-950nm
I already done first samples of:
MASS GX53 7W 48pcs SOL 2835
MASS 13W (not 15w or 14w) 60pcs SOL 2835
MASS 11w 36pcs SunLike 3030 6v
Photos and another information in my telegram — Telegram: Contact @sunlikenews
I just finalized last of the MASS models today ![]()
With 3030 6v SunLike TRI-R (3-R) from SeoulSemiconductor:
RIRERA 11 36pcs 3030 LEDs
33$ Ø58x130mm 130grams Δ38° E27/26 e14 GU10 gu5.3/mr16 B22
RIRERA 13D 36pcs 3030 LEDs dimmable
40$ Ø76x141.5mm 205grams Δ38° E27/26 e14 B22
With SOL 2835 3.2v SunLike TRI-R (3-R) from Smart Eco Lighting co ltd:
MASS 13D 60pcs SOL 2835 LEDs dimmable
~35$ Ø75.5x151.5(149)mm 231grams Δ41° E27/26 e14 B22
MASS GX53 48pcs SOL 2835 LEDs
~25$ 111 gram
MASS 7C 19w COB SOL
The same photo with 6C
~25$ E27/26 e14 GU10 gu5.3/mr16 B22
Compare of the size 11 and 13D
Futured bedtime bulb lamp with SOL SunLike 2200k 2250k
7w (asian style body with round diffuser) & 5w (special project body with round diffuser)
About discounts for MASS models
It was the reason why I created it
I think maximum discount will be 20-25% (with 6$ international shipping for any order) and will seems like that: 5+pcs = 5% discount; 15+pcs = 10% discount; 30+pcs = 15% discount; 50+pcs = 20% discount; 100+pcs = 25%
Wholesale price will be about 50% (without shipping)
Now all we need is to get those 2835’s in maukka’s hands. Methinks I’ll have a sizeable order to place!
he received parcel today, I hope test results will be soon, but there was also 4 bulbs :face_with_monocle:
Finally!
SunLikeMASS15D
Ø80x144mm 193grams Δ38° E27/26 e14 B22
35$
Wow, they certainly don’t disappoint. Looking forward to the other CCTs!
I have all of these!
SOL2835 0.5w Without diffuser:
Absolutely awesome.
- So is that 0.5w per LED?
- Is that wattage what you recommend for the balance of efficiency, longevity, and output?
- Still at about 70 lumen/watt?
Are these 6V like the 3030?EDIT: I see on your site they’re 3.2V - Possible to get them in 2200K?
- Possible to sell this in 5m flexible strips?
Looking forward to picking some of these up!
Looks amazing!
Some people prefer Duv to be right around zero (neutral tint), and others prefer it to be slightly negative (rosy tint), especially for warmer light.
Have you heard of this study?
Is it possible to tune these bulbs to also offer variants with negative Duv, say –0.005 and –0.010? This would lower color accuracy somewhat, but people might like the light more.
Tint mixing neutral light of different color temperatures is one way to do this.
60 leds 15w
It is mass, so, it will be in stock ready to shipping
About 75lm/watt in this bulb (with diffuser)
2200k only cob 6w what was produced specially for me by SEL (Smart Eco Lighting co. ltd.)
Only 12x99mm pcb with 3-12 leds плата с 4-12шт SunLike 3030 12x99x1.6мм 4P3S/2S 60-480мА
I have no spectrometer, but you can find any duv what you want. There’s many reviews of my lamp and leds.
It can be cob sol, cob saw (seoul semiconductor), smd 3030 6v, smd 2835, sunLikePlus, SOL cob without violet, S model with switching
Since the bulbs are being mass produced, can we still request specific combinations of CCT in a single bulb?
What CCT?
I know if it will be 2x4k+1x5k = 4200k and it is good spectrum
All another only with big order
That 4200K option may work. Ideally I’d get as close to 5600k as possible but with lower duv, so I’m curious what something like 2x 5600, 1x 4000 would produce.
It might be a good business move to mix 3000k and 4000k LEDs to create the elusive “true neutral” 3500k bulb. There are a lot of sellers selling 2700/3000/4000/5000k bulbs, but I don’t know of any selling a good 3500k.
I know you are thinking I must be basing this on personal opinion, but the ANSI standard “C78.376-2014” accepts 3500K as the true neutral.
Exerpt:
https://www.nema.org/Standards/ComplimentaryDocuments/C78-376-2014-Contents-and-Scope.pdf
