This light is powered by two Efest 10440 cells driving an XHP50 J4 1A emitter on a 10mm Sinkpad directly soldered into a large copper pill and heatsink.
The casing is made from 14mm OD x 1mm thick solid brass tube with copper & steel internals, bezel and switch detail.
It has a forward clicky tail switch with red tritium vial installed, an aluminium reflector and 12mm x 1.6mm multi layer AR coated glass.
Single mode direct drive
XHP50 J4 1A
ARC glass
Soldered MCPCB & pill
Forward clicky tail switch
Length - 140mm
Width - 14mm
Weight - 104gm
Max 1800lm OTF
Thanks very much, yeah it’s fairly floody but the reflector is also quite deep for it’s size.
There is just a slight hint of the crosshair in the beam, It sure heats up fast :laughing:
Sir, I’m in awe of your inspired builds. Every time I see a new CRX build post I get excited. Keep up the fantastic work and thank you for sharing these elegant designs with us mere mortals!
